HELP: Cam Tools
2nd2nunn
Phoenix
does anyone have the OTC part numbers for the wedge and spring compressor for cam swaps
GOTTORQ
Connecticut
no tools needed, plenty of guys have done it without them, including myself, shoot me a PM if u need some help, i used a garden hose
SirKnightTG
Deep in the <3 of Texas!
I didn't use the tools. Removing the roller followers by using the spring compressor is completely un-necessary. Just "inch" the cams slowly off and on and you'll be fine. It's also faster and IMO safer that way (b/c otherwise you risk knocking keepers off and dropping a valve and it doesn't take much of a bump to do that!). I also improvised on the timing chain wedge. It doesn't matter that much what you use or how you do it, just keep the tension on the chain so it does not slip off the lower sprocket.
trill gear head
Norfolk, VA
+1. I did this method also and it was a lot easier. I even bought the spring compressor and couldn't figure out how to get the freaking followers off. Just be patience and careful.
Goose
2007 GT/CS
South Florida
The spring compressor is 303-1039 and the wedge is 303-1175. The spring compressor should run you about $150 and the wedge $94.
5.SLOW
missouri
but you have to have the spring compressor to change the springs when the heads are still on the motor. right
