This article supersedes TSB 9-9-6 to update the Service Procedure.
Anyone else suffering from this issue, but the dealer wont fix it? My car always grinds going into 3rd gear when it is cold, yet the dealer tells me that is normal. I had this repaired one time, but it came back. I have had many problems lately, but the dealer can't seem to find anything. If this thing wasn't under warranty, I would tear into it myself.
Do you guys know this one?>
M/T - Buzzing/Oil Canning Noises
TSB 08-2-10
02/04/08
4.6L MANUAL TRANSMISSION - SEPARATOR PLATE
BUZZ - BUILT BEFORE 12113/2007
FORD:
2005-2008 Mustang
ISSUE
Some 2005-2008 Mustang vehicles built before 12/13/2007 and equipped with a 4.6L engine and manual transmission, may exhibit an oil-canning or exhaust rattle/buzz around 2000 - 2500 RPM during the first few minutes of driving after a cold start. The sound goes away after the car warms up.
ACTION
The concern may be caused by the separator plate, between the rear face of the block and the transmission housing, vibrating and/or contacting the flywheel. Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
1.
Remove transmission per Workshop Manual (WSM), Section 308-03B.
2.
Pry separator plate from rear face of block alignment dowels, slide out from between block and flywheel, and replace with new service part.
3.
Install transmission per WSM, Section 308-03B.
I just got busted with this tsb
Is there a TSB for a/c issues with the 2010 GT's?
Don't know how I missed that. (must be the blind thing) Thanks.Check post # 77 of this thread. This is the most recent TSB
05-8-8
Growl/grinding Noise In 2nd Or 3rd Gear During Deceleration - Tr3650 Manual Transmission - Vehicles Built Before 1/15/2005
mines 2008, got grinding noise at 3rd gear during deceleration... is there an TSB for newer S197's?
