Bottom line ....I need a replacement block to build upon. It needs to be STANDARD bore and ALL of my 3 valve stuff needs to bolt right up..heads,timing components,knock sensors,front cover and all accessories. If machine work is required THAT is not a major issue...everything just needs to work off my 06 engine. Weight is not really an issue so aluminum is not a requirement. I need it to be STRONG and have longevity. What do I need to find? Teskid, stock replacement (not really what I want...the one I have has issues that I don't want to repeat!), Aluminator? Please tap into your data banks and tell me what my options are and what I need to try and find. Thanks Don
