| 2005+ Mustang GT 4.6L Tech Technical discussion about the 2005+ Ford Mustang GT 4.6L |
Thread Tools | Display Modes |
#1 | |
Dyno Numbers - Who Cares?
Based on the recent interest in weight reduction, this thread is intended to be a clearing house for all things related to shaving pounds off our cars.
If you have actually weighed a part, post in this thread and we'll keep the list here in Post #1 updated. Let's also add aftermarket replacement parts, so we can see the difference between stock and its replacement. Please don't "guess" on the weights... that won't help us. Unless you actually put it on a scale, keep it to yourself. Also, if you notice any errors in this spreadsheet, post them up. Matt-D now maintains this list, and he will making updates to this spreadsheet as often as necessary to keep it current. ============================================== UPDATED 02/02/2010, 6:08pm PST ![]()
__________________
![]() 2005 Sonic Blue GT, A/T Personal Best 1/8 mi: 6.691 @ 103.04, 60' = 1.487, DA=1,166' (02/19/09) Personal Best 1/4 mi: 10.679 @ 126.51, 60' = 1.516, 1/8 = 6.813 @ 101.52, DA=3,998' (09/19/08... on old setup) Click for Video All-Time Best 1/4 mi: 10.373 @ 132.93, 60' = 1.524 (03/14/09) MAJOR MODS: Fully Built Boss 5.0 SB, Livernois P&P Heads, KB 2.8L SC- Engine Built & Tuned by S.T. Motorsports. Click Sig Pic to visit my Car Domain page for Full Mod List and Videos Quote:
#2 |
11 Sec NA Crew
I will add a bunch of numbers to this tomorrow, I have a hand written sheet sitting in my car :)
thanks for the sticky Don
__________________
Naturally aspirated 11.93 @ 117mph ( 1.57 sixty foot)|Full bolt on's|3210lbs|stock heads,cams,bottom end|
#3 |
Prepare for glory!
![]() Stock front strut assembly with stock brakes and calipers = 67 lbs each, 134lbs total ![]() Door assembly with trim and window / electric motors (but does NOT include stereo speakers and wiring harness) 81lbs for each door. 162 lbs total. Speakers accounted for in weight of stereo. ![]() A/C system, compressor, condensor, lines. 38lbs This was hard to weigh as the lines and stuff were very bulky. I threw everything in a tote and weighed it---then just weighed the tote by itself and subtracted to come up with the difference. ![]() Shaker 1000 stereo system complete 85lbs ![]() Wiper motor and wiper blades 9lbs (does NOT include washer fluid or washer fluid tank) Passenger side air bag: 7lbs ![]() Passenger seat (no air bag, no power) 48lbs Will weigh driver seat (with power) tomorrow, want to confirm the 60lbs, could be +/- a few Will weigh driver side air bag, stock hood, stock k-member with a-arms, back seat with brackets, seat belts. Last edited by psfracer; 03-03-2009 at 01:38 AM.. |
#6 |
KEYBOARD NINJA
9 lbs OEM axle tube weights (pair) <---- these ? if so ford added weights to some of the cars to help with noises fro the rear end , basically another trick to shut it up lol they are pictured here outlined in the red boxes
__________________
'08 vista GT .....Stock-ish ---sold '10 tuxedo black F150 4x4 '96 black cobra #657 '04 cobra motor , mvb aode , the works .....still under construction Last edited by Freaknazty; 05-19-2009 at 04:47 PM.. |
#7 | |
The lost guy.
Quote:
I didn't see any noise difference.
__________________
2005 Sonic Blue GT One day i will have a P3496
#8 |
11 Sec NA Crew
I weighed some of the same things paul did with some differn't results... I guess no two scales Are exact but here is some of my info... Just a bunch of stock weight numbers and after market, I will keep adding to this post , so keep posted!
Stock Parts All parts out of trunk/ Sound detonating 42 lbs Complete Ac system 33 lbs (not including underdash only in engine compartment) Stock hood 30 lbs Stock trunk 23 lbs (with no wing) Back Seats top and bottom 21 lbs (not including hardware for belts) Rear seat belts, brackets and bolts 9lbs Front seats with rails –Pass side 42, Driver side 50 = 92 lbs Stock rims/tire (51 pounds each) 204 lbs Stock rear lower control arms 12lbs Stock Oem windshield 28lbs Stock manifolds 20 lbs Stock h-pipe 32 lbs Stock sway bar 13lbs Sway bar brace 16lbs Wind sheild fluid tank (full) 8lbs Small plastic piece (stock belly pan that connects to rad support) 1 lb Stock k-member, a-arm, motor mount assembly 68 lbs Parts you will be adding or replacing with, so you can do the math with the stock weigh figures and get your total weight savings. Granetelli Sway bar Delete 3 lbs Bogart 15x3.5 Bare rim with alum centre cap 11lbs each Bogart 15x10 bare rim with alum centre cap 13 lbs each Kooks long tube headers 16lbs (pair) Kooks off road X-pipe 18lbs Racecraft K-member, a-arms and motor mounts 46lbs MMR Rear seat delete 9lbs (yes you will be adding 9lbs after you minus your seats and brackets) Corbeau FX1 Pro seats Suade 16lbs each Corbeau Seat brackets 9lbs each Upr full race lower control arms 4lbs
__________________
#9 | |
Quote:
You state the LCA to be 12 lbs, Don said 14LBs. Who is right? Also I would like to add stock front rotor - 19 LBS each stock front caliper w/line - 11 LBS each |
#11 | |
11 Sec NA Crew
Quote:
Mac Catback
__________________
#12 |
Aggressively Unhelpful
Are these weights each or for the pair?
__________________
'08 GT Deluxe It's just a car, and it's only money. |
#13 |
11 Sec NA Crew
__________________
#14 |
11 Sec NA Crew
Well I have a few front oem windsheilds in stock , Im going to weigh one and then call speedglass to see how the weight compares... This might be my next big thing, to replace front,rear,both side doors, and the 1/4 windows
__________________
#15 |
11 Sec NA Crew
So the stock front windshield weighs 28lbs... i thought it would weigh more.
I assume the back weighs just as much. I think if all the windows were replaced on the car dropping 50lbs might actually happen.. They are not cheap though lol but hey, what is?
__________________
#16 |
11 Sec NA Crew
Well I just got off the phone with speedglass.
They don't have the complete kit in stock to weigh each window seperate but they told for a 1/4 front windshield and all the rest 3/16 all the windows together weigh 40lbs.... Just some more info for you guys ![]()
__________________
#17 | |
KEYBOARD NINJA
Quote:
how much $ for the complete kit matt ?
__________________
'08 vista GT .....Stock-ish ---sold '10 tuxedo black F150 4x4 '96 black cobra #657 '04 cobra motor , mvb aode , the works .....still under construction |
#18 |
11 Sec NA Crew
good question... I know its over $1500 Canadian but its alot cheaper down your way... like 30% cheaper lol I forgot to ask ![]() sorry lol
__________________
#19 | |
KEYBOARD NINJA
Quote:
damn bro they rape yall up north huh sheesh 30%
__________________
#20 |
11 Sec NA Crew
well thats the exchange rate....... 1.30 so what ever is us price we have to add shipping, duty and exhange rate.. what happen to free trade xD
__________________
| Bookmarks |
| Thread Tools | |
| Display Modes | |
