| Tires and Wheels Want to know what tire to use? Have a wheel fitment question? Need to figure out which wheel stud to use with those new drag wheels? Post all of your tire and wheel related questions here. |
Thread Tools | Display Modes |
#1 |
Broke :(
I need to make a decision between the stiff wall or the regular ET Drag. I'm currently in a manual, but planning to move to a auto. What tire would be best for a 650rwhp + car?
Thanks
__________________
05 Mustang GT- PH 76mm Turbo, Stage 3 heads, 322 JPC Built RGR Stroker (under construction) |
#2 |
Im curious of this as well. My last track trip my bias plys drifted alot on me
__________________
http://i188.photobucket.com/albums/z...icture0349.jpg Full bolt on, Full exhaust, geared GT |
#5 |
On a radial tire, if the pressure is too low it will cup due to a stiffer sidewall & tread. A bias tires can run a lower tire pressure before this becomes an issue. Both tires will wrinkle, but the bias tire will do it much more than the radial since the tire pressure is generally higher and the sidewall flexes less.
#6 | |
Dyno Numbers - Who Cares?
I've always used the regular ET Drags, and have been very happy with them. As long as I ran at least 11psi in them, they were very stable. At 10psi, they would wiggle a little, but never to the point of being unstable. At the moment, I'm running a stiffer wall Goodyear slick. Even so, they still can wrinkle. Check out the video below from a month ago (at 11psi). But I haven't made a lot of passes on the Goodyears, so the jury is still out on them.
__________________
![]() 2005 Sonic Blue GT, A/T Personal Best 1/8 mi: 6.691 @ 103.04, 60' = 1.487, DA=1,166' (02/19/09) Personal Best 1/4 mi: 10.679 @ 126.51, 60' = 1.516, 1/8 = 6.813 @ 101.52, DA=3,998' (09/19/08... on old setup) Click for Video All-Time Best 1/4 mi: 10.373 @ 132.93, 60' = 1.524 (03/14/09) MAJOR MODS: Fully Built Boss 5.0 SB, Livernois P&P Heads, KB 2.8L SC- Engine Built & Tuned by S.T. Motorsports. Click Sig Pic to visit my Car Domain page for Full Mod List and Videos Quote:
Follow along with my house rebuild here: Bigger, Stronger, and a Lift! |
#7 |
I started running the stiff sidewall MT slicks.They seem to hook better on our track and even got me into the 1.50's at our local track in my 07 gt500.Never could cut low 1.50's on the reguler mt slicks.Then put the stiff ones on and always cut 1.50's.
Best I could do with the regular mt slicks was a 1.61. Less wrinkle will give a better 60' as long as the track hooks.But I've wrinkled that crap out of the stiffs and still cut my 1.50's.... At that time,I had about 580 to the wheels and about 600 tq
__________________
859 987 4222 OR 859 285 7250 |
#8 |
Broke :(
I think I'm going to give the stiffs a try. I see quite a few guys running them.
Hey Don, What size are those Goodyears? Do they rub at all?
__________________
#9 | |
Preferred Internet Drink
Quote:
#10 |
Broke :(
Thanks for the advice,
I just ordered two new MT 28x10.5-15s for 350 shipped. Now I got to fine some fronts.
__________________
#11 | |
I'm Dexolishous
Quote:
Where from? Didnt MT have these on clearance?
__________________
You're not your job. You're not how much money you have in the bank. You're not the car you drive. You're not the contents of your wallet. You're not your fucking khakis. You're the all-singing, all-dancing crap of the world. |
#12 | |
These are 29x11.0-15, and they do not rub anywhere. I was running 28x11.50-15 M/Ts.
__________________
#13 |
Broke :(
__________________
#14 | |
Quote:
However, I just saw on Saturday an S197 with the 30x12-15 destroy his bumper on the launch... ![]() I would say 29" is as big as you can go. |
#15 |
I have been running the 28/10.5/15 stiff for a little while. They seem to be better then the regular ones. My car whips the sidewalls so hard the stiff ones just seem to stand up better. Been running them at 10.5psi.
__________________
07 Mustang GT 5.4 Cobra Motor 2.8L Mammoth KB 9.01@ 152 mph in the 1/4 , 5.80@ 126 mph in the 1/8 1.40 60' http://i206.photobucket.com/albums/b...nFord008-1.jpg |
#16 |
I'm Dexolishous
hmmmm, maybe stiff is the way to go... I'll be running 700rwhp at the track
__________________
#17 |
Damn 10.5 psi? Do you notice any excessive wadding? Do you have rim screws on them? Perhaps the stiff can deal with it easily. The goodyears wad like mad and went to tire shake at 11 psi.
#18 | |
Quote:
Don't get me wrong, the tires are good for maybe 8 to 10 passes. After that the side walls are DONE!
__________________
#19 |
Okay...lol After the rim screws (inside and out) I didn't go into tire shake and it held up at 11.5 psi but I went to 14.5 cause it wadded like a mother. It hooked the best with low psi though, but as you said, the life dropped dramatically. I am using them at 14.5 now.
#20 |
My car eats tires.....
I think I spend more on tires then I do gas or Nitrous.....
__________________
| Bookmarks |
| Thread Tools | |
| Display Modes | |
