#61 | |
Lethal Mustang
Quote:
good lord ! that was a sick launch in your youtube vid vs the bike !! @ what rpm did you launch ?!
__________________
BMR - Steeda - Bassani - SCT - Spydershaft ![]() not fast enough
#63 | |
Quote:
Think maybe I can see a little air next time out with my new big and little setup? I'm going To try and get some video from different angles next time.
__________________
11.46 @ 116mph, 1.55 60', .001 RT on 04/03/09! http://videos.streetfire.net/video/F...409_644720.htm ![]() 15" summit stars w/ MH DR's FOR SALE!!! |
#64 | |||
I LOVE BEING BLOWN!!
Quote:
Quote:
Quote:
Lastly, they confirmed what Matt said above and after running it on the dyno and checking AFR, sicne it is a wet kit he said they don't need a specific nitrous tune, but that they will likely back off 2 degrees of timing from my tune. However, I've already asked Doug for a nitrous-specific tune....let's hope he gets back to me on time with that! I'll keep y'all posted....CAN'T WAIT!!!! ![]()
__________________
Scary fast, stock, black '10 GT500 Coupe I use CHEVRON/TEXACO 93 with TECHRON. "Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end." |
#65 |
Marc,
You said they put it on the dyno, what did it put down? edit: Hold up you said that you are running 125 and they are only pulling 2 degrees?
__________________
"MY children, it is permitted you in time of grave danger to walk with the devil until you have crossed the bridge." |
#66 | |
Quote:
Nothing's been done yet. The wet ZEX kit was ordered and should be in this thursday or Friday, so I don't know if we're installing the setup Friday or Monday. They keep the GT40 pumps in inventory, as well as the Brisk plugs. When they install they'll put it on the dyno and pull [quote]"one or two degrees"[end quote]. However, I've asked Doug at Bamachips for a nitrous-specific tune. Alternatively, I'm thinking of using my 87 tune instead of my 93 tune so as to start off with less timing. I've bolded, underlined and italicized the word wet above because my understanding is that there is somewhat of a difference between a wet kit and a dry kit. This ZEX kit come with a computer "controller" that only injects nitrous when the TPS is at WOT, and is constantly measuring the nitrous pressure so as to prevent dumping fuel into the engine when the nitrous runs out. This controller also keeps the AFR at whatever it set at when the system is set up. Can anyone explain the differences between a wet kit and a dry kit? Is the wet at WOT only and the dry a progressing/progressive stages thing?
__________________
#67 | |
- All Motor Crew -
Quote:
bad ass video man I just watched it! that dude on the bike must of been all bent outta shape ahahahaha by the way congrats on getting into the mag a few weeks back ![]()
__________________
Naturally aspirated (stock heads,cams,bottom end) 12.01 @ 113mph to date( 1.58 60 foot)
#68 |
Shut up and die!
Wet kits spray both fuel and nitrous into the intake. Dry kits spray just nitrous and the computer reads it and compensates with more fuel on it's own.
__________________
2003 Sonic Blue Cobra - 450whp/460tq |
#69 | |
Dragracer wannabe
Quote:
A dry kit gets fuel added through the fuel injectors and relies on your tune to add the fuel.
__________________
07 GT/CS, Roushcharger,CAI, 98 MM MAF, KB BAP, Pypes Off-road X-pipe, BMR LCAs, Relocation Brackets, Adj UCA, UCA Mount, Rear Swaybar, Front Swaybar Delete, Adj PH Rod, PH Rod Support, Tokico D-Specs, Ultralight One-Piece Driveshaft, FRPP 4.10 Gears, 35 HP Shot of Nitrous, Tuned at RET, Best 1/4-11.69 & 119.80 MPH, Best 1/8-7.325 & 97.198 MPH |
#70 | |
[QUOTE=MrClean;236807]Matt,
Nothing's been done yet. The wet ZEX kit was ordered and should be in this thursday or Friday, so I don't know if we're installing the setup Friday or Monday. They keep the GT40 pumps in inventory, as well as the Brisk plugs. When they install they'll put it on the dyno and pull Quote:
I've had the zex wet kit before and it is a respectable kit. The kit should be jetted rich enough from zex ( most companies jet their kits a little rich to cover their ass) and be safe. The only thing I worry about is pulling only 1 to 2 degrees of timing with a 125 shot (even if it is rated at the flywheel). A common rule of thumb is 2 degrees for every 50. This rule however is not set in stone and should only be used on baseline tuning when it is on the dyno.
__________________
#71 | |
Quote:
On my old 5 liter car I think I pulled around 3-4 degrees when spraying 150-175. Like someone else mentioned in the thread. Most nitrous wet kits are setup a little rich so that you can bolt and go with no ignition or fuel adjustments with the exception of leaning it out a little. All of my experience is with the NX or Dynotune (which did not produce enough 'hit' to me) Although NX claims no timing adjustments necessary on the 150 shot I pulled a little out anyways
__________________
-Lee 08 GT. JBA axle back, FRPP springs and swaybars 03 Super Duty. 84 SVO. to many mods to list www.streetstangs.net |
#72 | |
Quote:
thanks bro yeah that dude looked a little pissed after that run haha if you go on my comments on the video, either the streetfire link or the youtube link, his buddy who also races a bike wanted to challenge me saying blah blah blah but he runs nitrous on his bike... think they're pissed i posted me beating his buddy on the bike on there. ![]()
__________________
11.46 @ 116mph, 1.55 60', .001 RT on 04/03/09! http://videos.streetfire.net/video/F...409_644720.htm ![]() 15" summit stars w/ MH DR's FOR SALE!!! Last edited by mikeysgt; 04-29-2009 at 06:12 PM.. |
#73 | |
Nitrous Tech
Quote:
The rule of thumb is 1-2 per 50HP starting at 0hp....even for a 50 shot you should retard timing. Adding nitrous to the cylinder speeds up the burn rate of the mixture. By retarding timing you are not only reducing the risk of detonation, you are going to make more HP because you are igniting the mixture at the point the piston will get the most force applied to it. I would also never run nitrous on the stock heat range plugs. Alos for those stating richer is safer, this is also not true. You can hurt a motor being rich just like being lean. If the tune is so rich that you are not burning all of the fuel in the cylinder it can linger on the cylinder walls. It will then get trapped inside the ring lands and be ignited on a future combustion stroke, this can cause catastrophic failure. |
#74 |
This thread has been a lot of help. good thread. thanks for eveyones input. from what I can gather if I stay under a 100 shot i'm safe with factor fuel pump but i might need to think about colder plugs. and with some luck on my side i could see mid to low 12's I think that is great times for a daily driver.
__________________
![]() 4.10's, shortie headers, tune(brenspeed), cats removed and axle-back exhaust, springs, shocks/struts, and short-throw shifter, CAI all FRPP. |
#75 |
yup. stay with a 100 shot, get some ht0's and good custom tune. go run 11's on your DD and call it a day ;)
i'm done with car mods for a while. time to focus on other things now. hoping the 15" setup will get me just a step closer to 10's since that will be my last mod for a few months...
__________________
#76 | |
Quote:
Interesting statement. I have a lot of experience with using small nitrous kits (175 hp or less) and have never heard or known of anyone retarding timing at all with 100 hp or less jets installed unless installing in a honda or something like that (75 shot is big for those motors) I agree with spark plug statement though. Definitely should go 1 heat range colder
__________________
#78 | |
USA MADE - SPARTAN BRED
Quote:
OMG!I would never say this,exept for a situation like this.. that fool got we he deserved..IMHO. In over 13yrs of running nitrous,mainly in FI applications.I have NEVER had any catostraphic failures,or incidents like that,wow. If you dont respect nitrous,it will bite you in the ass. As for timing retard..for me.I dont retard anything under a 100 shot.But..I also make sure I'm loaded with sunoco 100. Start small,monitor a/f, bottle press. and go up from there. |
#79 |
I have always used NX octane booster for years. I have always ran a wide-band o2 sensor to know what my A/F is a wot. Keep A/F at 12.5 or less to be safe at wot. Some canned tunes may have timing advanced to the edge & easy for you to pull 2-3 degrees with a hand-held tuner. Over 100 hp shot may require colder plugs but not 100 hp or less same with fuel pump. No one mentioned a good adjustable bottle heater set to come on at 1100 psi to 1150 psi & turn off at 1150 to 1200 psi. After a purge you should leave on at least 1100 psi. Not a real fan of Zex stuff but on small shots should be ok. Just don't use a Zex bottle heater use a good adjustable one like Harris Speed sales also they have good bottle heater & blankets. LOL
| Bookmarks |
| Thread Tools | |
| Display Modes | |
