one eyed willy
Pizzle fo shizzle
There has been some recent debate over the 2 different pumps.I recieved my gt500 pump today. i took both my stock pump and the new gt500 pump apart. used a digital caliper tool to find the different specs on each pump.housings are 100% identical,every opening i could measure was all the same. the pick up tubes are the same part number on each one.the gears were also identical.so i pulled out the spring and little valve that was inside.springs were the same, i put a weight on each one and got the same height, valves speced out to be identical.
only difference i found in the 2 pumps were the plugs that hold in the spring, the gt500 pump was .93 tall and the gt pump was .73 tall.from what i can tell by the passages, the spring and the valve, the bigger plug should equal higher pressure. the bigger plug would apply more pressure to the spring and valve, so oil would be restricted making more pressure.
gears
outside housing
inside valves side by side
gt500 guts
inner housing
2 plugs side by side, gt on the left and gt500 on the right
label on the box
quick way to see the diffence in the pumps would be to take a look at the plug,regular gt is black and the svt was zink colored.
gears
outside housing
gt500 guts
inner housing
label on the box
