I went with this set up because I wanted the added capacity of this tank, while at the same time have roughly 50lbs of water-ice over the rear tires. After a 1/4 mile pass, I still have ice in the tank, water still cold, and the intake air temps are usually about 82-86 degrees when I pull up to the line, and anywhere between 96 and 104 degrees at the end of a pass.
I guess I am kind of confused when you use the word "coolant". I think of coolant as what is in the radiator. The I/C tank has nothing more then water and ice.
Inlet is at the top. The pump is mounted directly underneath the tank, so even when almost completely drained, the pump is still being gravity fed water at all times, to keep air out of the system.
The pump is moved from the stock location (front) to the rear, directly below the tank. The pump needs to "push" the water, not pull it.
When I first hooked up the system, I did have some air in the lines which worked its way out after a day or so. Ever since then, I have not had a problem with any air in the system.
When I turn the key on, but do not start the engine, you can hear the pump come on and the water flow. I never had a problem with ice blocking the line or whatever. However, when I fill the tank, I only drain about 2/3 of it, while 1/3 remains water. Then I fill it with ice and there is still plenty of water, (in other words, its not like slush)
