Is 22 lbs through a 3.4L too much boost to run on pump gas? The motor is 9:1 CR. I'm planing for 650-700 to the wheels, so that makes me believe it will be ok...but... IDK.
we are about to try 19 psi. on a 9.3:1 compression motor on 93 octane....should find out if it works in a couple days....I am sure if you run a lower timing it will work....
i have been wondering the same...all we have is 91 octane here so been wanting to know where to push it to...i have a lower compression block so not sure how that helps me. i am at 8.25:1
