05stroker
Never enough power guy!
Ok so I know about the adjustable units and how they leak . I have Livernois lockout with the phasers locked in full advance and would like to properly degree in the cams . Last time in tuning the banks where off enough from each other that it had to be tuned for . I have a set of Comp custom grinds with these specs.
Int. Exh.
Gross valve lift .491 .501
Duration @ .006
Tappet lift 261 265
Valve timing Open Closed
@ .050 INT. 3- BTDC 45 ABDC
EXH. 47 BBDC 1- ATDC
These specs are for a cam installed with a 114.0 centerline
Intake Exhaust
Duration @ .050 222 226
Lobe lift .4910 .5010
Lobe separation 114.0
I am looking for help on how to properly degree them . I have searched for quit some time today and found allot of info , but not specific to a mod motor . If anyone has a link or even better a video of a mod motor being done I would love to see it . From what I have gathered so far I will need some solid followers and the degree kit of course . From what I have read today with the lockouts in full advance and the cam specs I am working with I should be around a 109 - 110 centerline and my cams call for a 114 centerline . Four degrees seem like a lot to me .Is it ? Another question I have is how do you keep the chains tight while degreeing the cams ?
Int. Exh.
Duration @ .006
Tappet lift 261 265
Intake Exhaust
