tmcolegr
It's All About the Build
Has anyone installed one?? Pictures??
It should, we've installed one on a Saleen with the Extreme inlet tube.I ordered one today from Lethal Performance. Should have it Friday. Sure hope it fits with the C&L Racer inlet tube.
That's what I was wanting to know - pictures would be even better. I'm using the C&L Racer inlet tube, Saleen S/C, GT 500 throttle body & spacer and a Be Cool Radiator. It will be interesting to see if it all fits.It should, we've installed one on a Saleen with the Extreme inlet tube.
Yes it does.. the canton sits in the same spot.... cant even tell a diff once its in. I have one on mine.That's what I was wanting to know - pictures would be even better. I'm using the C&L Racer inlet tube, Saleen S/C, GT 500 throttle body & spacer and a Be Cool Radiator. It will be interesting to see if it all fits.
Why would you think that it might not fit? It isn't any bulkier than the stock tank.
I have one for sale if anyone wants one.
It's very easy to relocate the PS reservoir if need be.
I'm getting ready to install the tank on my car right now. Can I just pull off the tubes on the bottom, reattach on new tank, refill with fluid and I'm go to go? No bleeding required, right?
