Kaldar142
So i've been having this 'slight' vibration issue for a little while now, i used to not have it. I didn't change anything when it started happening either.
It used to happen on acceleration & deceleration but i rebalanced my wheels and now it just happens on deceleration. it used to be a 'slight' vibration over 110 when i was off the gas / in neutral but today i went cruising with a few buddies and we did a few top end runs and now my vibration is REALLY bad.
I was going WOT up to about 160mph with no vibration, but as soon as i let off the throttle it felt like something in the rear end unsettled and my car was about to fall apart... i got back on the gas and it went away.
I would get on/off the gas (around 140mph) and i would feel a weird clunk, like something was coming loose but as soon as i get below 110mph its fine.
It only happens when i'm coasting down, when its unloaded... The vibration was so bad at the time i wasn't sure if i was going to make it home. I stayed under 80mph the whole way back and it was fine.
Any ideas?
I have a 1 piece aluminum driveshaft, rebuilt rear with 3.90s, Steeda competition rod end LCAs, Steeda relocation brackets, CHE adj. poly UCA, and Fays2 watts link.
Any ideas?
