Random Asshole
meow
The story:
My ABS unit failed on me going into a 90 degree bend at 120mph at the track monday. The good news is I set two records: One was track record in my class and the other is for most violent crash. The bad news is I'm out a car. I'm OK aside from some soreness, but the car is pancaked. Fortunately, there was no fire and the driveline survived. I was thankful for once that our cars are as heavy as they are.
I'm trying to find an '07 body to match mine in v6 trim with the same options to make things less troublesome, but prices have jumped up considerably since I last looked.. I found a BASE 07 (auto trans) with what looks like absolutely no options for just under 10k and it looks tempting since I have an entire parts car.
After spending hours searching/PMing with Texasblownv6, here are my questions: My car is a manual, btw
1. Aside from swapping the pedals over, everything under the dash should be the same? I realize the shaker stereo and mycolor system will not be there, but that is none of my concern for now as long as it runs. I'm pretty sure the clutch switch connector will not be there, but its necessity can be pulled out in the tune according to SoundguyDave.
2. Will the pcm trigger a "dummy light" for oil pressure in the base gauge cluster instead of the faux gauges in the IUP dash cars? Or am I just best off swapping the cluster, panels, and airbag over? I've seen threads on cluster swaps in the past, but haven't got back to those yet. Like I said, just trying to get things running asap.
3. I only found one post mentioning the need for a k-member swap and it didn't sound "for sure." Since the motor mounts to the frame rails, are they really different between v6's and 8's? I'm afraid mine is probably tweaked. The trans tunnel and floorpan "rails" are 3 inches closer to the opposite side.
4. Since the donor PCM is for a ABS car, the only thing I have to worry about is the "abs light" in the dash and codes? Can it be "tuned out"?
Also, here's the summary of what I've found so far and wouldn't mind corrections or add ons to anything I've missed to guide my decision in whether or not to purchase the base car:
- PATS key system will have to be reprogrammed.
- Use same year body so electrical connections mate up.
- Fuel line from hard line in firewall to rails need to be changed, otherwise fuel system is the same.
- Trans cross-member is the same, just flipped around with a different rubber mount. (my original one snapped in the crash)
- driveshaft and rear end will need to be swapped.
- A/C and power steering hoses are different.
Anything else?? The car I found is going to be purchased tomorrow based on my findings. Any input is greatly appreciated.
Thanks
Carl
P.S. Please don't start saying, "just buy a v8", I looked into that. Not likely happening due to financial reasons.
Thanks
Carl
