tmcolegr
It's All About the Build
Question For Those w/Strange Engineering's C-Clip Eliminators
I have the complete 8.8" axle housing out from under the vehicle and stripped down to the bare housing in preparation for the following mods:
Notice the rolled material. Isn't that burr that's protruding about .020" going to prevent the new caliper mount supplied by Strange Engineering from seating properly and ultimately causing a leak? Looks like the housing has been that way since new. It has never posed a problem up until now because nothing seals on either of those registers. I'm probably going to carefully machine that burr off while the housing is up in the lathe getting the outer ends removed just to make sure I don't have any leaks.
Has anyone else run into this?
- Detroit True Trac w/ARP Ring Gear Mounting Bolts (Already have FRPP 4.10s), including new differential carrier bearings
- Pinion Flange (installing an Axle Exchange 4" One Piece Aluminum Drive Shaft) using the latest style pinion flange nut and collapsible spacer
- Strange Engineering Safety Hubs (C-Clip Eliminators) includes modifying axle housing
- Moser Engineering Main Cap Studs
- Welding the Axle Tubes
- Welding the BMR LCA Relocation Brackets
- Welding the BMR Sway Bar Relocation Brackets
- Modify Coil Spring Mounting Pads (more on that later...)
- Install BMR Dual Durometer Axle Housing Bushing
- Painting or Powdercoating the axle housing
- BMR UCA Mount
- QA1 Single adjustable rear shocks
- M/T ET Street Radials - P295/55R15 or P325/50R15
