05stroker
Never enough power guy!
I'm in the middle of wiring my TCS unit . I have a question about the TPS and VREF connections . On my unit it calls for the orange wire to be connected to the TPS VREF and the Green wire to be connected to the the signal from the TPS. There are 4 pins in the connector for the TPS, they are as follows.
1 YE/WH THROTTLE POSISION SENSOR SIGNAL
2 RD/LG THROTTLE POSISION SENSOR REFERENCE VOLTAGE
3 BK/LG SIGINAL RETURN
4 GY/WH THROTTLE POSISION SENSOR SIGINAL
Now with that said is number 2 the VREF and number 3 the return from the TPS ?
Also the directions have a white wire marked starter relay and another marked Ign. start. I understand these are for the neutral safety switch , but want to double check my research . I am planning on connecting the wire marked starter relay to C1035B pin E10 WH/PK and the ign start to C1035B pin B9 WH/PK .
Keep in mind on some models , depending on trans , these last two wire may be RD/LB or a combination of both but, the pins should be the same .
