claudermilk
Those are some MIGHTY expensive angle-brackets! I would bet you could fab an equivalent for maybe 10% of that. Also, it's really not that hard to drill the holes for eyebolts. Even if you want to go "back to stock" at some point in the future, you're really only looking at three or four small holes which can EASILY be plugged, plus two slits in the carpet, also easily repairable if it comes to that. When you put force on a cantilevered bracket like you were showing, it's really less than ideal, since they can bend and yield.
Also, there's absolutely no issue from a safety standpoint with a 4-point rollbar in a street car. All the tubing is well behind the seat, and well away from any bits of you that may be flailing around in a wreck. A CAGE, on the other hand... Not so bueno. I'm not a huge fan of harness bars, but I honestly can't say with authority that they pose a safety risk. I just look at the force vectors and kind of say "hrm...." if you follow. A big ole' jungle-gym behind the seats, anchored solidly, though is another matter. Granted it's just an "eyeball engineering" thing, and I do tend to over-build, but...
Yes, expensive. I was thinking that since my welding skills are not the best, this would not be a good place to use them. I will have to search around for some good pics of the eyebolt install (I'm betting Terry has posted some that I'm forgetting about or missed). I don't mind the overbuild bent. I am sometimes called "Capt. Overkill"
I have thought the same thing regarding a 4-point bar. Especially with the Recaro seats which help keep your noggin away from the main hoop. The issue for me has been rear seat use; I still need to use them on the street occasionally & that isn't a good fit. However, there's a new thread pointing to an option that either I hadn't seen or is new from Watson Racing for a 4-point bar that can be removed. The main hoop mounts in the same place as the popular MM one, so that makes me happy. It's something to investigate.
comfort for your manly bits is a huge plus to a 6-pt
Got it in one! A 5-point has the strap heading straight south from the buckle, right above the old "wedding tackle" which for some may be uncomfortable. A 6-point (particularly if it uses a T-bar design, like Schroth) puts the straps up against your thighs, and is MUCH more comfortable.
LOL, 'nuff said. 6-point it is. The wife would kick my ass if I damaged myself down there.I have seen some nasty, nasty photos of rally drivers who have crashed with 5 point harnesses and done some serious damage to their family jewels. There's no need to post that here, but if you can opt for the 6 point, I would do it. Even if you're not planning on putting your man parts to work, some serious pain can be averted.
Again, thanks for the excellent info. My wishlist is getting more focused. Enough of my slight hijack of this thread.
