tmcolegr
It's All About the Build
Has anyone experienced a failure of one of the solenoids in the solenoid pack?
I had an issue on Saturday. Transmission completely lost 4th speed and reverse. Shut the vehicle off. No DTCs. Restarted the vehicle and went for a 45 minute drive with about 50 upshift/downshift complete sequences and the transmission shifted perfectly. Went for another drive on Sunday and transmission shifted perfectly.
This morning I called Tony @ Larry Transmissions and after a lengthy question & answer discussion, he suggested replacing the solenoid pack as he has seen them fail. Reverse and 4th speed also use the same solenoid.
Called Ford next and it would seem that Ford has just released a brand new part number for the solenoid pack - 9L2Z-7G391-A (2009 part #). Oddly enough, my dealer had one on the shelf.
This Saturday I will be dropping the pan to check for any abnormal debris. If all looks good, I will install the new solenoid pack.
