BlackGT
Unfortunately a couple of weeks ago the car had about an inche of water in the passenger side foot well. I cleaned it up, dried it out, it didn't spell of mildew and once everything was completely dry no issues. It has rain multiple times since.
This morning, for the second time, I found about an inch of water in the passenger side foot well, I couldn't do much about it because I had worked a double, and had to go home and sleep for another shift in 7 hours. Once I'm at work, another thunderstorm came down on NJ, and when I proceeded to check for any possible further damage, the car had several inches of water. I had a rag sitting there from this morning, it was soaked, I squeezed multiple cups worth of water out of the car.
At this point in time I'm beyond annoyed. My warranty let up February, it's unbelievable that this just happened now. I've downloaded the TSB from Ford, but because the pictures are pretty much computer drawings, it's touch to get an idea as to where the exact locations they are referring to check.
I'd appreciate any help with this. As in any advice as to where your personal clog was, because Ford has you check 10 different places, I rather start at the most common first. Any in person pictures taken of where the issue could come from would be appreciated as well. Any advice whatsoever will be appreciated because I need to try and fix this by Sunday. I'm just hoping the carpet isn't infested this mildew underneath.
The one thing I will check is the air filter, I've read that mold loves to grow on them. Whoever read the entire post, thank you. Yes, I've done research in this thread, and not much recent information has come up on this topic. I will continue to do more research, and I myself will provide information if I find any, and once everyone is cleaned and cleared to help anyone else with this shitty problem. This should be a recall considering the extent of damage that can be caused to the car.
Update: What I did notice on initial check of the floor, the first go around, is that nowhere on the side, upper, or back part of the carpet is wet. It's almost as if it's coming from underneath, which is odd. I'm going to check near the fuse box area. I've heard of the smart box's going bad. I also want to note that, so far, I do not have any electrical gremlins whatsoever.
