A/C Troubles. need advice
irishpwr46
Official Site Vandal
NYC
so i drove to the gym today. it was raining pretty bad. had my defog on with the A/C on the way to the gym. everything is running fine. get to the gym, workout, come back to car. still raining. go to turn on my A/C, but the compressor isnt coming on. is it possible that on my way to the gym, something got wet and burnt out? all fan speeds and temp controls are working fine otherwise, but when i hit the A/C button, or when i put it on max A/C, the compressor doesnt engage. ideas? thanks in advance
94tbird
4R70W FTMFW
NY/NJ
check the easy stuff first. no specific order.
A/C cycle switch, located drivers side engine bay towards the firewall. It is in one of the A/C lines
A/C power switch, located on the side of the compressor
Make sure there is R134a in the system. Its designed to not come on if the refrigerant is low
Check fuses
irishpwr46
NYC
08 gt all connections seem dry and tight. gonna have to take it to my mechanic to check the pressure.
94tbird
4R70W FTMFW
NY/NJ
you can check it real quick by unplugging the ac cycle switch and jumping it with a wire or paper clip. It will turn on the compressor regardless of refrigerant. If it turns on, your looking at low refrigerant. If it doesn't, you may have a bad coil on the A/C compressor itself. Easily repaired.
irishpwr46
NYC
UPDATE: had my mechanic take a look. he can get the Clutch to engage when he grounds out circuit 85 in the fuse box. its a gray/white wire going back to the computer. he said its possible it needs a new computer. he told me to ask around before doing anything though.
skwerl
tree hugger
central Florida
You said it was raining. Do you have water intrusion at the SJB? I've heard all kinds of issues when that gets wet.
BruceH
BBB Big Bore Boss 322
It may just need charging. There is a pressure switch near the radiator on the drivers side. If there isn't enough pressure for the switch to make contact the clutch won't engage.
irishpwr46
NYC
Pressure is ok, I had it checked. I'll have to look into the sjb. Does anyone know offhand if there's any ac relays in there
Sprayer84
Omaha, Nebraska
Does your mechanic have access to a diagnostic tool that will show him a data stream from the bcm? You need to see if it is even being commanded on when you use the dash controls. I wouldn't jump to conclusions about a bad computer yet.
TexasBlownV8
Formerly TexasBlownV6
Central Texas
Relays and fuses. The SJB has a fuse. BEC has a couple fuses plus the relay.
Do you have any DTCs, is the car running ok? The reason I ask is that power that feeds through the relay coil is provided by PCM relay #1, which also provides power to other circuits, including the O2 sensor heaters and other things.
I had a o2 sensor wire get shorted out and blow the fuse. It was the fuse right above the "1.0" black diode when standing over the BEC from the passenger side fender, next to the a/c relay.
irishpwr46
NYC
So I took the car to ford. They recharged the system and said they were able to get the compressor to come on with a computer hooked up to it. They tried blaming my tune first. After that they said it was a bad ground and that I would probably have to get a new ecu and sjb. Any thoughts?
skwerl
tree hugger
central Florida
Sounds like they are throwing parts/money at it hoping to fix it. Some shops have mechanics, most just have parts changers.
