Need help trouble shooting codes
05stroker
Never enough power guy!
Bullard Tx.
I have these codes.
P0135
P061c
P0743
P0750
P0755
P0760
P02106
I am going into fail safe a short time after starting the car. I started off with 19 codes after my build since I have deleted allot of stuff and rewired the entire car. I have worked though most of them with my tuner. I know the 700 codes are for the auto trans that was deleted in the tune and the codes should not be there anymore but for some reason they are even though these codes have been disabled. The P0135 is a o2 sensor code that could be from the new exhaust from fumes,comtamination, or bad heater in the sensor its self. I have done some research online and found that the P061c has been associated with some transmission failures in F150s as well as bad crank sensors ect.. The P02106 is a limited power code for the throttle body due to one or more of the other codes.
My question is this . Will these trans codes cause a fail safe condition? Also does anyone have anymore info on the P061c code? I have searched and searched and this is where I am at now.
Here is a link to my build. Start at the last 10 pages. LOL
http://s197forum.com/forum/showthread.php?p=1181391#post1181391
lito
Caracas, Venezuela
That is not the way to do this, it won't never work by disabling stuff in the tune.
Have this tuner ever done an auto to manual (or non 5r55s auto)?
05stroker
Bullard Tx.
Yes, 2 of them with Lentecs and the trans funtions are turned off in the computer. Not sure on a manual swap, never asked.
Let me guess, I need a manual PCM ?
lito
Caracas, Venezuela
No, your current auto PCM will work, you may need a new tuner, lol.
