exhaust manifold stud
skwerl
tree hugger
central Florida
Looks like I screwed up today. I have some cat delete pipes and today I began working on the install. The upper bolts on the clamps holding the pipes to the exhaust manifolds are difficult to reach and there isn't enough clearance for most sockets. With a short socket it won't reach the nut and with a long socket the back end is against the catalytic converter. I ended up using a long socket with a swivel with the socket cocked to the side slightly.
I got the right side broke free but couldn't budge the left side. So I buttoned everything up and took it to a buddy's shop. With his impact I ended up rounding off the nut but got it off. I tried to put a brand new nut back on the stud and the threads were toast so now I need to replace the stud. Where do I find one? NAPA? The dealer? A speed shop?
TexasBlownV8
Formerly TexasBlownV6
Central Texas
Try other local auto parts places; many carry various bolts/studs. Our Advance Auto Parts has such bolts, some, but not all; I've gotten a few from there.
If you get the stud out, you can always use a bolt on that one side instead.
skwerl
tree hugger
central Florida
Is there a gasket between the pipe and the manifold? I'm assuming there is, metal on metal couldn't seal that well.
BruceH
BBB Big Bore Boss 322
A fastener store would be the best bet. FWIW I've never been able to remove those nuts without a pb blaster soak.
Alfiedagr8
Bakersfield CA
Do not buy just any bolt or nut. YOU MUST buy OEM studs and nuts. The nuts are special for exhaust system and are locking nuts so they don't back off. Use a stud extractor to remove the stud and buy one at the local dealership. If I look Carefully when u buy a new one. Look at the threads. They look weird. ( you will know what I mean when u see it) also there is no gaskets. The pipes are flared. Ford been doing it this way for Evers. Let me know if u need more info.
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
I had no gasket on mine when I switched to LT's and O/R H, it's a ball and socket type setup so it seals.
fdjizm
Drag Queen
NY/NJ
No gasket, it's a ball and cup joint, they seat then squeeze.
Ampire
3 valve
Maryland
I have seen generic sized exhaust manifold studs at autozone and advanced auto. Otherwise, order it online.
skwerl
tree hugger
central Florida
We were trying to match up the threads with other hardware and couldn't get any standard or metric nuts to work. 2-3 turns and then crossed.
I don't believe I'll need a stud extractor, these can be removed with a deep socket (hex section in the middle). I have one other stud that started backing out when removing the nut. I'll probably buy all four studs and nuts new, exhaust fasteners are always difficult to reuse.
fdjizm
Drag Queen
NY/NJ
Holy shit! I just got off the phone with the dealership and the studs are $50.26 EACH! :thud:
You can get them for cheaper I bought four of them online I think it was fordpartsgiant.com don't have the part number around but I have two laying in my toolbox. I snapped two lol
skwerl
tree hugger
central Florida
I'm thinking I'll go ahead and remove that loose stud and then start hitting up the local parts places before proceeding further.
skwerl
tree hugger
central Florida
I found a package of exhaust studs hanging on a hook at the NAPA store. Three of the four original studs had the threads maligned at the end, resulting in both the studs and nuts stripping when you try to remove them. The car is almost new and it hasn't been touched before so I can only assume that Ford intentionally sabotages the threads to discourage modification/ removal of the cats.
All four studs and nuts are replaced and the cat delete pipes are installed. I had to cut the tape holding the O2 sensor plugs in place in order to get enough slack to reach the bungs. I used zip ties to secure the plugs again. I need to bend one pipe hanger back into place the next time I remove the rear wheel, I bent it pushing the pipes back when I separated the H pipe.
Redfireshaker06
Central Florida
I used the NAPA ones. Its studs without the shoulder like the stock ones.
NAPA Exhaust Manifold Stud & Nut Kit
PN: 600-1819
Contents : (2) Studs, (2) Nuts
Exhaust Manifold Stud Length : 62mm
Exhaust Manifold Stud Thread Size : M10-1.5
List price: $10.51
