Broken exhaust manifold stud. HELP
skwerl
tree hugger
central Florida
Yesterday I began my transmission swap to install a used 3650 after a local shop ruined mine. I wasn't willing to let them touch my car again after finding numerous stripped bolts, everything was tightened with an impact gun, broken and missing parts, etc. It was really bad.
The driver's side exhaust was overtorqued to the point where the nuts stripped when removing the exhaust. One of them I was able to remove and replace, but the other one went south on me. First all the threads stripped off so I had to use my Dremel to cut off the nut. Once the nut was off I couldn't get the stud out. I heated the manifold and hit the stud with ice and that didn't work. I borrowed a stud extractor and that just sheared off the rest of the threads. I used the Dremel to cut flat sides in the collar so I could grab it with Vise Grips and that didn't work. So I cut the stud off flush so I could drill it out. No problem, I have 3 sets of drill bits as well as the correct size tap to clean up the threads. I got a 1/8" hole drilled through but when I stepped up to the next size the bit snapped off in the stud. I can't get anything in from above to punch the broken drill bit out due to the curve of the manifold.
Now what do I do? Do I have any other options than to remove and replace the manifold? I'm not sure if I can get to all the fasteners without disassembling half the engine. :thud:
skwerl
tree hugger
central Florida
OK, what all do I need to remove in order to remove the driver's side exhaust manifold? Lots of guys here have done headers in their garage.
Captainstr8edge
Hardcore Superhero
North shore, MA
I did the same thing. I was using one side for a little while, then I made a makeshift clamp. Then when my motor went I got another set locally cheap. My dad owns a metal fab shop and they couldn't get it out, so your best bet is to do a swap. Might as well get long tubes since your going to be doing the work anyways.
skwerl
tree hugger
central Florida
I found a diamond bit in my Dremel case and that seems to be making some headway. Now my battery is dead so I need to wait about 30-40 minutes for that to charge up again.
Looking at it a bit closer in case I still need to remove it, looks like I can block up the motor and remove the motor mount bracket and the steering shaft and get all 8 manifold nuts from underneath. Thankfully my BMR K member gives me quite a bit of access.
fdjizm
Drag Queen
NY/NJ
That's going to be rough, I'd say try to drill it out completely ruin the threads then use a regular long bolt to put it back together instead of a new stud. or throw that shit out and get a replacement!
Swarzkopf
This. The right drill bit will power through that.
What kind of drill do you have? A good drill helps, too. My 8 amp DeWalt gets through just about anything.
skwerl
tree hugger
central Florida
That was an excellent suggestion! My Dremel wasn't charging up quickly enough so I put the diamond bit in my Makita 18v cordless drill and got around the broken drill bit. Then I drilled it out big enough to throw another bolt in there. It's not pretty but it's on!
white05gt
Illinois
I just saw this and even though it's too late, a welder and penetrating oil would have taken it out with no problems. I would have welded a washer to bolt then welded a nut to the bolt/washer then cool it down spraying with a good penetrating oil. Once it's cool to the touch you can take a wrench and back it right out almost every time.
fdjizm
Drag Queen
NY/NJ
Good stuff that will definitely hold bro! it's just a clamp so that's all it needs anyway.
AnotherS197GT
Serial Valve Dropper
USA
I have a set of manifolds sitting in my garage. If you want to replace that one let me know and I'll send them to you for the cost of shipping.
skwerl
tree hugger
central Florida
Bruce, I'm not seeing a lot of advantages to headers. The stock manifolds are pretty open and with the cat delete pipes there isn't much resistance. On the other hand, headers would make other tasks much more difficult. This is a used transmission I just installed and the clutch is just an off-the-shelf brand so the likelihood of me having to go back in within the next year is high. Headers would need to come off to do that.
At some point I would love a T56 but it's simply not in the budget right now.
