Brezick
Yinzer
- Joined
- Jul 14, 2011
- Posts
- 1,386
- Reaction score
- 0
Purchased a long block out of the classifieds here and it had quite a few issues with it. After cleaning up the heads, and freshening the shortblock, its finally up and running.
Prior to this, I had:
Stock block, heads, cams.
Kenne Bell 2.6L - 9lbs boost
Kooks LT headers.
Dyno @ 439/427
With the suspension and misc upgrades, my best time is 11.47@122.
Changes:
9.0:1 compression forged 4.6 shortblock.
3.25 pulley - making 15lbs boost
Comp 127550 cams
Phaser lockouts.
FRPP 62mm TB
found the lower compression while tuning and not too thrilled as it was advertised as stock 9.8:1. will make due with it as I may just get a smaller pulley for more boost.
Final pull I was 517/461, i believe it was only 15 degrees timing and steady 11.7 A/F, so it is a little conservative.
So 78hp/34tq gain which should do me ok. I was expecting more, but maybe with the lower compression and the lockouts, it is probably losing some.
Hoping it can give me a 10 sec slip and I will be happy with the car.
Kooks LT headers.
Dyno @ 439/427
Changes:
Comp 127550 cams
Phaser lockouts.
FRPP 62mm TB
