DYI: Radar Detector (V1) Hardwire Install (the thorough method)
MrClean
Marc; but I go by MrClean
Friendswood, TX
RD= Radar Detector
First remove the Glove Box (while closed, remove 4 7mm screws at the bottom of the glove box, then press the sides in so that the box releases from the catches, and out it comes.
Next, remove the A-Pillar cover. Your factory pillar is attached to the car with five mounting clips that lock the pillar onto the unibody. To remove the original piece, work your fingers under the edge of the pillar at the rear of the driver’s door. Applying even pressure, pull the pillar away from its mounting point. A firm, slightly quick motion will release the upper
clips with ease. Once the upper clips are free, continue to pull the pillar downwards releasing the mounting clips as you work towards the dash top. be carefull with the last one, almost to where the A-pillar meets with the dash...at this point the clip is just a guide that is slipped into the A-pillar cover, and mine fell off and rolled into the area between the glove box and door frame, and I had to waste 10 minutes looking for it. There's a vid link of the removal courtesy of Don_w (2nd from the bottom).
2005+ Mustang Pillar Removal and Installation Video:
Optional: Removal of the passenger side kick panel. This is the panel that the fuse panel is behind. Remove the insertable fuse panel cover, and tug at the kick panel from the bottom, pulling towards the drivers side (there's one pressure snap there), then tug towards the rea of the car to release the 2nd pressure snap. At this oint you notice you have to partially lift the piece along the botton of the door, the step area, because the end of the kickpanel is tucked underneath it. Lastly, tug the slim vertical piece from the door frame towards the rea of the car.
Now you have unimpeded access to the areas yoou need.
I started wiring at the RD, and tied the wire around the rearvew mirror mount, so that if the RD's suction cups come unstuck, the weight of the RD wouldn't pull the wire out of the headliner. I then wrapped the wire in 3/8" flexible black plastic ribbon conduit, and ran the conduit from directly above the rear view mirror, tucked just inside the headliner, to the passenger-side corner where the headliner meets the A-pillar.
At this point you will see a wiring harness for all electrics inside the car's dome. I used strips of white duct tape to tape the RD's wire to the harness, following the harness all the down, into the innars of the dash and to the fuse panel. The easy way to thread it down there is to insert the left arm/hand under the dash, while the right hand is feeding the wire; when the lfet gets a hold of the wire, pull and continue to tape the wire to the harness.
Instead of splicing into a wire (which in theory could overload a circuit), I used an "Add-A-Circuit" fuse jumper, and placed it in one of the empty fuse holders (#15) in the passenger footwell fuse panel. #15 was empty, but turns out its "switched"...I tested it when I had all the wiring hanging out, the V1 connected and turned on, and the key in the ignition. This means the V1 now has a dedicated circuit, a safety item IMHO.
The pic of the fuse panel shows that #15 is the empty slot under the middle 5 Amp A/C Cycle fuse (middle from top to bottom) on the 3rd column from right to left. I also made a U-shaped hole in the fuse box cover for the wire to exit freely. The V1 hardwire harness comes with a snap on splicer that makes it very easy to connect the V1 harness to the Add-A-Circuit. The ground wire from the V1 harness was bolted to a bolt that secured the entire fuse panel assembly to the car's body.
Used a 3 amp fuse in the add-a-circuit, but its redundant because the V1 hardwire kit comes with a traditional shaped (cylindrical) fuse in-line (you can see it in-line on the red wire).
I then secured the V1 hardwire harness to the kick-panel, leaving the in-line fuse in the V1 harness accessible when the fuse panel cover is removed.
Looks professional, and now I won't forget to turn the dang thing on, and I can see my TC button again...gotta love a clean, uncluttered dash, and no wires visible except the 6 inches coming from the headliner to the RD, which I placed just under the rear view mirror. Thisposition is optimum for radar detection, while down low on the dash is preferable for laser detection.....the thing is, by the time your detector warns you of laser, and your brain processes whet is going on, the cop already has a readout of your speed, so to me the laser detection is more of an FYI: "FYI you just got nailed!"
<!-- / message --><!-- attachments -->
donnyonee
or just tug hard at the overhead housing and it pulls loose quite easily, connect your + wire to the black w/blue stripe and your - wire to the all black wire. it shuts off automaticlly after 15 minutes so you dont need to worry about draining your battery, messing around in the fuse panel or trying to hide the wires. my escort 8500 only draws 220 ma that i believe is less than 1/4 amp and i have it running thru a 2 amp fuse cause that what i found at pep boys. thered be no problem running this with any exsisting circuit and any more than 1 fuse is a waste of effort and $. some pinhead might call this half-assed. but it is a 5 min job, reliable, safe and easy as hell. imho.
if you really need pics maybe you should do it the first way or have it done.
whichever.
edit; if you need to see it i'll be at irwindale this thur evening 7/26 and show it to you. i should be w/ adams group.
edit;
for you guys that stopped by- thanks for the compliments, it was good meeting all you. (3)
MrClean
Friendswood, TX
or just tug hard at the overhead housing and it pulls loose quite easily, connect your + wire to the black w/blue stripe and your - wire to the all black wire. it shuts off automaticlly after 15 minutes so you dont need to worry about draining your battery or messing around in the fuse panel or trying to hide the wires. its a 5 min job and easy as hell.
whichever.
Just a minor point, but by doing this you're piggy backing on a circuit that is wired and fused for whatever it is feeding....this way you have a dedicated circuit that shuts off with the ignition switch. Two items addressed: reliability, and safety, but yes, that is another option, although I tugged on the overhead console pretty hard before trying it my way, and the thing separated from the headliner a good ½ inch but never came off...
MrClean
Friendswood, TX
Dude, each to his own: you're perfectly happy with doing it the half-assed way, and that's ok, not everyone is cut out to do things thoroughly, to take the extra step.
Same reason some people get further along in life than others.
MrClean
Friendswood, TX
As in "driving a pinhead with a sledge-hammer" (I plead guilty), or was that an insult?
C
Crossss
Guest
Nice write up. I'll be using it when I install my V1. Here's a link for company that makes custom brackets for radar detectors if you want to attach them to the rearview mirror. They started making them specifically for 350Z's then branched out to other cars including +05 stangs.
http://www.countryjoycrafts.com/350Z/valentinemount.htm
:rock:
MrClean
Friendswood, TX
donnyonee
nice mount! ive already had to replace the silly suction cups once and their not very reliable, mine fell once while doing some serious driving at willow springs.
2k05gt
Manassas, VA
you guys are lucky you can have a detector...
They are Illegal in Virginia.
Chris B.
PA
The ground wire from the V1 harness was bolted to a bolt that secured the entire fuse panel assembly to the car's body.<!-- / message --><!-- attachments -->
Thanks for the install guide. The only thing I did differently was use one of the bolts near the back of the glove compartment with a ground wire already attached to it to connect the V1 harness ground wire. The bolt that secured the entire fuse panel assembly was much wider than the U shaped metal connector on the end of the ground wire in the V1 wiring harness. The one behind the glove box was the same diameter as the U shaped metal connector in the V1 wiring harness.
Eric298
Got V8?
Virginia
1st off nice write up Mr clean i adjusted my original setup after reading this.
btw 2k05gt you do realize its only a 40 dollar ticket in virginia with no demerit points. I live in the communist wealth of virginia as well currently running a V1 and dual head laser jammer setup. Which i should probably do a write up on as well.:idea:
speedofsound
The gauge pod guy
Memphis, TN
I *REALLY* like the guy who wrote this! :thumb:
:roflmao:
Nice writeup on the job, glad our tips could help a little.
MrClean
Friendswood, TX
:roflmao:
YES! Your video was a God-send! ( I was scared of busting something when removing that piece, so your video gave me great guidance, and I just HAD to reference it):clap:
