aimso
I currently daily a 2007 Mustang GT that has begun experiencing a bad knock from main/rod bearings.
The cheapest option is currently a used motor. I wanted another mustang motor, but they are way too expensive in comparison to the 4.6 3V from the 05-09 Explorer/Mountaineer/F-150. I am not racing or building this motor -- I just need something to make the car run.
I understand the motor is cast iron, but does anyone know of the main issues with this swap? I can swap everything from my current long block (that isnt the bottom end). Are the heads the same across these motors? Will I need an adapter plate for the motor mounts (or know where to get some?).
Just looking for advice/see if anyone else has done this swap prior! Thanks!
