SpiredFate
I've been trying to diagnose an A/C issue with my 2012 Mustang GT for some time now and all the things I try have had no results. My A/C will not come on. I replaced the A/C compressor & condenser about 2 years ago. I have replaced recently in an effort to fix the issue: the A/C Clutch Cycling Switch as well as the radiator fan. It has optimal Freon levels, all related fuses are good and the A/C relay is functional, and bypassing the relay causes the A/C to work fine. The radiator fan comes on with the manual climate control set to A/C as intended. If anyone can point me in the right direction with this, that would be grateful.
