2007 GT/CS
"Oderint Dum Metuant"
Understand most of the basic information just need clarification on a few points:
- Adjusting timing - The Zex instructions warn against using *any* performance tune (even with the 75 shot) which has not been adjusted for nitrous (timing reduced). Is this really an issue or can I run a 75 shot right on top of my Brenspeed 93 octane tune without additional adjustments?
- Adjusting timing (part deux) - So when going to the 100 or 125 shot do I really need a custom N20 tune ($75 from Brenspeed) or can I simply use the customizing features with the SCT to modify my base 93 tune to remove the requisite degrees of timing? If so, what timing vs rpm ranges did you use?
- Nozzle location - Again, the ZEX instructions call for placement 6-18" in front of the throttle body. Opinions here? Further is better (to provide N20, fuel mix according to BSpeed's instructions) but to what point?
