I figured Air Fuel Ratios would be a good topic to discuss.
Some of the things I'd like to look into are:
- How Lean is Too Lean
- How Rich is Too Rich
at WOT:
For N/A ~12-13
For FI ~11-12 (more boost goes towards 11 - less towards 12)
- What are Contributing Factors of Being Rich/Lean
Rich = too much fuel
lean = too much air
J/K - sorry had to...
other than "tune" calling for the wrong thing...:
1. lean - unmetered air entering the intake (air leaking in after the MAF in the intake path)
2. lean - bad/mis calibrated MAF
3. lean - too much timing
4. lean - low fuel pressure
5. rich - bad/mis calibrated MAF
6. rich - fouled plug (not firing/burning the gas)
- What are Things to Troubleshoot in a Rich/Lean Condition
See above:
1. tune wrong (just plain wrong, or failed to account for IAT?)
2. MAF bad/mis-calibrated
3. missing clynders
4. insufficient fuel flow/pressure
5. air leaks in intake after MAF
6. engine temperature
- What are Acceptable Ranges in Being Rich/Lean
See ranges at top for WOT - when in closed loop (idle/cruise), the PCM will try to bring you up to ~14 - 14.7. Of course the A/F will fluctuate any time you change the pedal position rapidly - all of the values stated thus far are typical "targets" for a given state (closed loop or WOT).
- What are the Negative Effects of Being Too Rich/Lean
Rich:
fouled plugs, wash cylinders (break down lubrication of rings and grind cylnder walls), foul cats, generally contaminate oil/lubrication
Lean:
overheat engine, burn piston/valve/spark plug components, detonate (break everything... )
- Air Fuel Ratios at: Idle, Cruise, Part Throttle, Wide Open Throttle
See above - WOT is different for N/A vs FI. At part throttle/idle/cruise you are closed loop and will be high 13 to mid 14's
