Windy_3V
I’ve been having various lighting issues with my ‘07 3 valve for a while now. My passenger side headlight has been out for a while and I haven’t figured out why. However, if I turn my high beams on it works just fine. So far I’ve replaced the bulb, both connectors going to the headlight, re-soldered the wiring, and replaced both low and high beam relays and neither fixed the issue. None of the fuses are blown either which wouldn’t make any sense anyways since the drivers side works fine.
Recently I noticed now my passenger side brake light doesn’t come on either and only comes on if I have my parking lights or normal headlights on. My third brake light and fog lights have gone out too but they’re kind of old and probably just the bulbs but I haven’t bothered trying to replace them either since they could have the same issue as well.
I’ve read that the SJB can be an issue on these cars but I don’t know much about it besides the fact that you can’t get them anymore and if they’re damaged you’re only options are to get it repaired or try to clean it up yourself. Also I’m not sure where it’s located but from what I’ve read it’s under the fuse box in the engine bay?
Also it’s worth mentioning I have aftermarket headlights and taillights (Raxiom DRL Projector with LED bulbs and Raxiom Gen 5 respectively) and didn’t have any issues when I first installed them which was years ago.
I’m running out of ideas so I’m thinking it has something to do with the SJB but I wanted to get a second opinion before I do something stupid and fry all the electrical in my car lol! Any help is appreciated!
