the PMP system consistes of twin GT Supercar pumps in the basket with upgraded wiring to each. there are 2 feeds coming out of the basket (gt500 kit has 1) that feed a y block. the y block is attatched to a -8an rubber pushlok hose that is rated for 2500psi. this gets run to the front of the car where it hits a second y block which splits the fuel back and feeds each furl rail individually, without the need of a crossover. this ensures the passengerside of the car will get as much fuel as the drivers side, with no pressure drop from one side of the motor to the other, as often found with crossovers with fuel systems. also, with both rails being fed seperately, if 1 GT pump should fail, it iwll still feed both sides of the motor adequately to get you home, vs a crossover where the drivers side will suck more fuel than can be reached to the pass side.
