I've been searching the forums, but haven't found the info I need. I have emailed BBR, but I wanted to get more opinions from the forum. I haven't heard back yet.
I'm using a BBR methanol injection plate under my KB 2.6L. It's been installed for a long time, but hasn't been hooked up to the meth yet.
I used Permatex anaerobic gasket maker as a sealant between the plate and the manifold. My tuner recommended this because it never hardens, and it makes it easier to remove the blower from the manifold (as opposed to gasket sealer, which makes it very difficult).
I was told by a reputable forum member that I should not use the anaerobic sealer with meth, as his own experience was that the meth degraded the sealer to the point where it caused a vacuum leak.
Can anyone give me a recommendation for something that will work better? I'm about to take the blower off to work on some stuff.
Thanks!
Thanks!
