I was replacing the spark plugs in my 05 mustang gt, the car has about 85k miles. Four of the eight spark plugs broke even after a long soak. All four broke off with the porcelain flush with the bell. I used the lisle tool from amazon for $60 and it did a good job off removing the broken pieces out of the four cylinders. When I was using the pusher tool to that pushes the porcelain down into the end of the bell of the spark plug, I tightened to far and it broke the tip of the ground strap( see pics). I'm worried about the pieces that fell into two of the four cylinders that I used the tool on. I tried using a air gun and was thinking of rigging up a small diameter hose adapter for the shop vacuum. If anyone else has some advice, it will be greatly appreciated.
Thanms
Thanms
