Powered by Ford
- Joined
- Jan 27, 2011
- Posts
- 1,143
- Reaction score
- 1
I traded my suspension setup to another forum member for his KW Clubsports that he believed needed to be rebuilt.
After contacting KW tech line I learned that they do not assist with DIY'ers who want to rebuild their dampers. They told me only KW authorized technicians could rebuild the dampers and they required "special tools".
So without spec cars or oil information gmitch and myself decided to tackle the project. Maybe some of you know this gmitch has a background in rebuilding and revalving motorcycle shocks.
First off it seems that KW underestimated that we have 908ssp who is a master machinist/fabricator (I mean c'mon just look at pictures of his car). 908ssp was able to machine out the damper rod clamps and the threaded cap (4 post).
From left to right: damper cap wrench, rear shock damper rod clamp, front strut damper rod clamp, and lastly a re-purposed Penske shock clamp
First the strut and dampers were taken apart.
Strut
Damper
Carefully remove all of the components (o-rings, spacers, etc) in the order they were removed.
All strut components on the left and all shock components on the right.
Using the clamps that 908ssp made we were able to separate the damper rod from the inner rod. The shaft assembly was disassembled because they chrome plated rods will be titanium nitride coated for a reduced friction mu and better thermal properties (reduce the amount the oil is heated up by the shaft). I will go into how KW's valving works later in this post/thread.
While dissembling the front and rear spring assembly (it is composed of both a tender and coilover spring) we noticed that the spacer was composite. You can see it was deformed due to the spring forces. Again 908ssp was able to machine a set of aluminum spacers to reduce the change for deformation due to spring forces.
After inspecting the springs that are standard from the KW Clubsport kit I decided that they were a bit much for a dual purpose daily driver (on nice Michigan days) and a HDPE/track day toy.
Springs that came with the KW Clubsport kit:
Front: 570 lbs/in
Rear: 340 lbs/in
With the street comfort factor in mind and referencing what both gmitch and 908ssp run on their coil-over setups, I decided to run the following:
Front: 60 N/mm -> 343 lbs/in
Rear: 50 N/mm -> 286 lbs/in
The new springs were yellow and I did not really care for that color all the steel parts were sent off to be powdercoated "race red". Also all the aluminum parts from the caster camber plates were sent off to be anodized gold. Just a little bling since we are already in there.
The shafts were dropped off to be Ti-N coated, so now it is a waiting for all the components to finish being coated.
That left one last question what oil should we use? We did measure the oil level of the damper so we did know that these dampers required for their internal air spring (these dampers do not have a bladder so therefore they are not gas charged, making them more similar to motorcycle/dirt bike forks).
After calling around a few places we found that KW uses a light oil. Luckily gmitch had some extra Ohlins light shock absorber fluid laying around, Viscosity 14,0 cSt at 40C.
I will update more as we rebuild the struts, including some technical information on the valving and how it uses a ZF Sachs style spring on the piston assembly.
![8880534562_41ca723ff5_b.jpg](/proxy.php?image=http%3A%2F%2Ffarm9.static.flickr.com%2F8535%2F8880534562_41ca723ff5_b.jpg&hash=a37ff17a349b8ae773137972e6ff6593)
Strut
![8880590780_1bdd9261fa_b.jpg](/proxy.php?image=http%3A%2F%2Ffarm8.static.flickr.com%2F7460%2F8880590780_1bdd9261fa_b.jpg&hash=1b8833437f523b688d6494ff4bc3c55e)
Damper
![8879914599_8dac8b6b68_b.jpg](/proxy.php?image=http%3A%2F%2Ffarm4.static.flickr.com%2F3671%2F8879914599_8dac8b6b68_b.jpg&hash=0f247a66654731d6bd663c19c3f693b9)
![8879913937_0fd44c38f3_b.jpg](/proxy.php?image=http%3A%2F%2Ffarm4.static.flickr.com%2F3765%2F8879913937_0fd44c38f3_b.jpg&hash=29f6c8f1cdfc547c2ff2401a28f7f7cf)
![8880534168_932fbd9b67_b.jpg](/proxy.php?image=http%3A%2F%2Ffarm4.static.flickr.com%2F3667%2F8880534168_932fbd9b67_b.jpg&hash=1b73279ea32aa31ecb8f3a56287d933f)
![8879913527_25c61ce529_b.jpg](/proxy.php?image=http%3A%2F%2Ffarm3.static.flickr.com%2F2862%2F8879913527_25c61ce529_b.jpg&hash=ee1f1cdf1811899a2e457e0fce7c4145)
![8880533858_189e4239ee_b.jpg](/proxy.php?image=http%3A%2F%2Ffarm8.static.flickr.com%2F7288%2F8880533858_189e4239ee_b.jpg&hash=623618b1b99f6ad87ad8e4b0af01e11e)
![8880533818_255b81e603_b.jpg](/proxy.php?image=http%3A%2F%2Ffarm6.static.flickr.com%2F5321%2F8880533818_255b81e603_b.jpg&hash=a4411b2cceab01e431dda588d3820e46)
Front: 570 lbs/in
Rear: 340 lbs/in
![8880533722_821b55da9d_b.jpg](/proxy.php?image=http%3A%2F%2Ffarm4.static.flickr.com%2F3749%2F8880533722_821b55da9d_b.jpg&hash=3affd6634cd58769d178a85ca1e83d37)
![8879913203_cdb090a2cf_b.jpg](/proxy.php?image=http%3A%2F%2Ffarm8.static.flickr.com%2F7403%2F8879913203_cdb090a2cf_b.jpg&hash=949f8a3e9623515a6be9f2ec201281f2)
