I have a set of Weld draglite XP'S, 15X8 with a 5.5" backspace. Do i need to use sway bar relocator brakets with these wheels?
Don, Will i still need the three inch studs even if i have long lug nuts? I guess i need to bring the wheels out and try them.
+1 to fin1. If the center of the 15x8 is as thick as my 15x9's, then you'll need 3" studs to be legal (and safe).Most techs likes to see threads or at least the top of the studs showing on rears so they know your lugs have enough engagement. The NHRA rule book break it down to exactly what is needed.
Don, I currently have the closed end lugnuts. The only thing i'm worried about when using them is will they thread on the stock lugs enough, it doesn't look like they will. Did you use the closed end lugs with the 3" studs or stock studs?
I used them with the 3" studs. When I test fitted the wheels with the stock studs, I was not thrilled with the amount of thread engagement. I didn't feel safe with them. That's the primary reason I went to 3" studs (being legal was secondary at the time).Don, I currently have the closed end lugnuts. The only thing i'm worried about when using them is will they thread on the stock lugs enough, it doesn't look like they will. Did you use the closed end lugs with the 3" studs or stock studs?
No one has ever said anything about the closed lug nuts I used either... but now that I have open ones, I don't have to worry about it. Like you said... it's peace of mind.For the same reason Don stated (anal tech) I have open lugnuts on my 3" studs so they can see them. Ironically, of the 5 different tracks I've been to, not one of the even looked, but hey... it's piece-of-mind.
That depends. The lugnuts for my XPs are shank type, and won't work with my street Bullitts (which use a conical seat type). I ended up buying these for my street wheels. They are long enough to fit over the 3" studs, and still look nice.Don, If i get the 3" studs can i still use the closed end lugnuts with my stock wheels or do i need the open end lugs. I usually go to Atco on street nights and they really don't check anything unless your go really fast.Then all rules apply. So i'm not overly concerned if i use the closed end lugnuts.
If you decide to sell these wheels please PM me with a price as I am interested.Thanks guys for your help. I measured them today and they are 15X9 and from taking measurements i will definately need three inch studs. My wife tells me i should sell them and get 17" wheels.
