Larry_H
Custom Motors Built
- Joined
- Apr 5, 2007
- Posts
- 172
- Reaction score
- 4
Well, as a lot of you know, I am building motors. I called around to order bearings yesterday and found out from not 1, but 10 suppliers that I use that undersize rod bearings will no longer be available for the cobra cranks. The SOHC cast cranks, same deal..but, there are more of those still left in the supply chain, but once they are gone......Standard sizes only from all bearing mfg's.....Don't know why this is happening....I just know that in the whole country, I could only find 7 sets of .010 rod bearings...Now, there are none in any distribution center in the US.....So, unless you run across a parts house that has some sitting on a shelf.....they are all gone.
I'm just passing this along for information purposes.....Seems like now, if you have a cobra crank and you need to turn it, your choice is going to be either have it built up and then re-ground to stock specs or not use it.....
It doesn't bother me that much, since I have the capability to do this, but for some of you that only have limited services machine shops, this could turn into a problem...I know that getting a crank welded up and turned isn't a normal machine shop function..They usually send them out to be turned...expensive machinery involved.
I hope I am wrong about this. I would be very happy to have someone prove me wrong, but the evidence so far says I'm right......
__________________
__________________
