Morris
- Joined
- Jan 19, 2012
- Posts
- 822
- Reaction score
- 1
I went to the track tonight expecting nothing more than to get a little seat time. It's been hot so I knew the DA would not be as good as last wed. I knew I would probably not be able to best last weeks outing of a 12.31 but I wanted to work on the launch.
I have a 2012 gt with a barton shifter, bmr lower and upper arms with the relocation brackets, koni shocks (set to soft) and steeda sport springs (I know not good for drags). The tires are Continental dw 285/35/19 front and rear. I have no cats and and modified exhaust with a BAMA tune. Gears are 3.73 on a MT.
I was able to get all the runs but one in the low 12's with a new best 60' of 1.82. The best run was the last with the tires at 22 psi (possibly too low?)
dialed a 12.19 and ran a 12.201 but lost the race on a poor reaction time of .193 The 60' was 1.861, 330' 5.185, 1/8 7.9, 1000 10.233 with a trap of 114.35 I was still hitting the limiter right before the line. I got luck tonight and got a bracket trophy out my efforts, a first for me.
My thoughts are that I should switch to a softer spring (bmr?) and get a drag set up to make it into the 11's. I was thinking of the dark stars in 15x10 with a MT ET street tire in 275/60/15. This should help the 60' as well as get me a few more mph on top as the tire is slightly taller.
I'm wondering what you guys think? Should I go this route to get to the 11's? I know most of the fast guys are going with a 3.55 or even a 3.32 gear but I'm hoping that I can hold off on that until I get a power adder.
I would eventually like to get some boost on the car and switch the gears but that will not be in the budget for a year or two. I don't want to make mistakes with the purchases so I'm looking for a little advice on if my selection are wise choices.
I had a fun time tonight and did far better than I expected. Looking forward to making improvements and any suggestions you guys might have.
