- Joined
- Apr 5, 2007
- Posts
- 6,356
- Reaction score
- 58
Not ET Streets or DR's, but those of you using MT Slicks, what psi did you find worked best for you?
I started at 11, went to 11.5 and I'm now at 12 (cold of course). I may continue to go up in 0.5 increments. The "wobble" diminishes with more air pressure. I felt it a lot at 11psi, but I hardly even notice at 12psi. Oh, these are 28x10.50-15's.
My best run at Englishtown was at 50ºF with my tires at 18psi.Peter, that sounds good on 'paper' - but I've never got traction even with the ET Streets with anything over 14.
The lowest 60' time (1.542) was at 12psi, but we had a couple in the 1.54-1.55 range at 11.5, too.That's what I have.
I don't really care about a little wobble, but what I want to know from you Don, is at what psi did you net your lowest 60'?
According to M/T tires that are less than 30" in diameter n a car over 3,000 lbs a minimum tire pressure of 16psi should be used.
The higher the pressure you can use while hooking the faster you will be.
http://www.mickeythompsontires.com/tech.php?bulletin=s3
