- Joined
- Apr 5, 2007
- Posts
- 6,356
- Reaction score
- 58
A got a couple emails from friends asking what was the deal with all the 'bad luck' I have had and wanted to try to give some tech info in the process of what I've found the hard way over the last 2 years. I actually didn't have that much 'bad luck' just more an expensive learning curve...
From the beginning, I wanted to do something no one has done - I wanted to have a true DD 9 sec S197. Tall order, I know, but I figured it could be done. (still think so)
My first attempt was on the vortech. I never 'blew up' the vortech and at 14 psi and below, the car was worked like a charm. Had I been satisfied with that, I would have never made any changes. I could not keep a tensioner on the car no matter what after 14 psi. Even when I had an unbreakable tensioner, it would then just rip the pulley right off at the bolt. The problem was directly due to my having a 4 speed AOD with no lock-up. Because the trans free spun, it was too much of a shock for the design of the vortech serpentine. I may have been able to overcome the problem by switching to a 6 speed , but I honestly was hooked on te AOD from day 1 and wanted to make it work.
I opted to scrap the vortech and go for a Powerhouse Turbo system. I wanted to elliminate the belt issues altogether. I blew a motor that was due to tapping a piston from a bad set of heads and that was bad luck and then I ran into the true trouble with turbos (for what I was doing)
Getting the car to run 9's on the 76mm blow-through set-up was not a problem at all. If I wanted to have a smokin' fast track car, I was there and could have just dialed it in. The truth was the car was NEVER going to be streetable as a 9 sec car. The heat issues and driveability were never ending. Fix this, and this would become a problem. Cool intake temps down and timing was an issue. Fix timing, and IAT's were ridiculous. The construction of all the turbo kits out there also made it very diffcult for any kind of decent cooling mock-ups (on a complete street car) without cutting up and shaving down the car which I never wanted to do.
I know there are some fast turbo kits out there as seen by Dyno Joe, Mike Schropp, and others, but believe me, if they are running 9 sec power, they are having a hell of a time with streetability and heat. I not only wanted the car to run 9's, I wanted to be able to drive the car 250 miles to do it if I wanted with the a/c and radio playing. Not saying you 'can't' do it on a turbo kit, just that I was not able to do it and wasn't going to be able to do it inthe near future.
Thus the change to the KB. Only because KB has worked out some tensioner issues with me and are confident they can keep the tensioner, pulley, and belt on with my trans, I am trying this last route to make my idea happen. If it doesn't, no more trying - I'll keep the KB at 15 psi and have a great street/strip car and have fun. This is definitely my last hoorah at gettin' er' done.
The personal satisfaction will be great if I can accomplish this feat and that's what keeps me going. I'd love to drive to an event in a REAL DD street car and lay down mid 9's and DRIVE home. Not just 'street legal' but a 'street car'. May never happen, but I'm sure trying...lol
This is why my car seems 'forever broken'. The moral of the tech part of this is to set a reasonable goal that has been tried and proven and stick to it or be prepared to spend enough to own several stangs...
If you think my goal is easy, just try to find one doing it. I've always thought a 9 sec trailer car is just another 9 sec car. But a 9 sec true street car is a sight to behold....
