Steeda pullie set, *rwhp gain + help in quarter mile*?
RedFire07GT
11sec N/A 3V
Ocean County, NJ
NEED HELP!!! I cant find a three prong pulley remover anywhere! the ones i found are all to big and wont fit between the balancer and the radiator? Where did you guys get your tools from for the install!?!?!?! THNAK YOU
Casey4s
Woodbridge, Va
NEED HELP!!! I cant find a three prong pulley remover anywhere! the one si found are all to be and wont fit between the balancer and the radiator? Where did you guys get your tools from for the install!?!?!?! THNAK YOU
Did you remove the fan shroud first? That has to come out first.
I used a Lisle three pronged puller with no problem, I also used a pulley installer tool but you can do it with the supplied longer bolt.
RedFire07GT
11sec N/A 3V
Ocean County, NJ
No i did not. It doesnt say anywhere to remove the fan. I think the threeprong one i bought is jsut to big. its a 7" stretch one
Casey4s
Woodbridge, Va
OK, you have to remove the fan shroud with the fan. First disconnect the two expansion tanks from the shroud. Just leave the connections in tact and push them to the drivers side. Disconnect the electric plug to the fan on the pass side of the fan shroud. Then there is just one small bolt on either side of the shroud (near the top) and lift it out. it takes a little jockeying but it just sits in a slot on the bottom so no bolts. Then there is plenty of room for almost any puller.
RedFire07GT
11sec N/A 3V
Ocean County, NJ
i jsut got the bolt off. i had my borther hold the belt with the balancer and i just lossend it and it came out. Im going to go bak to the store nd buy a smaller 3prong puller. see if it works if not ill PM u back. Thank you for the help! Really Appretiate it!
Casey4s
Woodbridge, Va
If you pull that shroud you should be able to use the puller you already have. Try it before yo buy another puller.
Casey4s
Woodbridge, Va
Getting the bolt off is easier than reinstalling and torqing the new bolt. Just put your car into gear and set the hand brake and you should have no trouble with the bolt. This whole install is LOT easier with the shroud outa there.
Beauch
New Car / Old School
Brew Town
If you use an impact it takes about 1/2 second to crack the bolt loose. You don't need to "hold" anything. The link from TMS is a good one and the one I followed.
Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
Any Advance or Autozone should lend you the pulley puller instead of you having to buy one.
Charlie Sheen
Armed and Hammered
Infernum ubi sum
On an auto, you can't torque the crank bolt unless you somehow lock the torque converter. And that TMS link? :roflmao: Look who wrote it.
Casey4s
Woodbridge, Va
How did you hold the torque converter?
Like this, it takes about 5 minutes to attach the tool and remove it again. It will hold the flexplate to loosen the cranlk bolt or to torque it to Ford specs.
craven
Banned
on my manual was completely easy, just put car in 4th and pull ebrake up....gotta love a manual lol
RedFire07GT
11sec N/A 3V
Ocean County, NJ
eah it ended yup being a hardr install then what it was, All my three prong pulley removers were to big for my car. Ive got alot of tools from my dad b/c he was a mechanic but he also worked on trucks, the three prong removers he ahd were huge lol. so i did rent a smaller one form autozone and it worked fine.
i did have the car in gear with ebrake on.
wht67
Jenks, OK
Where do I get one of these tools?
What is it called and where can I get it?
Thanks,
Wayne
Casey4s
Woodbridge, Va
You just need to be smarter than the torque converter. Steeda suggests holding the flexplate with a wrench. Well good luck with that, it would take two people and I really doubt you could actually hold it safely that way.
It's a guy named "Taco Bill" from TMS who has a lot of really decent write ups. Some guys need a little outside help to do some of these add ons others don't.
