Just so you guys know I am on here to help spread tech to you guys and maybe get some of you to look at things from a different perspective, this perspective will allow you to have a better understanding of how and why things work like they do.
Here is a link to a post I made in regards to RWHP numbers, hopefully you can understand that they are simply a gauge,
http://s197forum.com/forum/showpost.php?p=218000&postcount=30
Boost in PSI is often times wrongly viewed. It is really Intake manifold pressure vs. atmospheric pressure, or manifold pressure delta-p. Because we seldomly know the actual atmospheric pressure we simply refer to manifold pressure as boost.
Superchargers are driven by the crankshaft, which means that the supercharger will always drive at a specific ratio when compared to the crank. This ratio is what determines supercharger speed, this speed is what dictates how much air (CFM) is drawn into and processed by the supercharger. This CFM or volume of air being pumped out of the supercharger creates "boost" or manifold pressure delta-p.
This "boost" is actually the engines reluctancy to accept a given volume of air. This can be realized in a case where someone may add ported heads, cam and stroker kit to a supercharged angine, if the pullies remained unchanged you will actually see the "boost" drop. Is it because the supercharger is delivering less air?, no. It is simply because the engine is more accepting to the volume of air being delivered by the supercharger, remember the blower speed and volume are unchanged because our drive ratio is the same as it were before our stroker/head/cam/ swap.
Some people refer to pullies as "14psi pulley", not the case, the pulley is a given diameter, not a given pressure.
Now if we have a day when the bar. press is low we will still see the same "Boost" (because our pressure delta-p is the same) but the actually the air delivered to the motor is less than it would be on a nice, clear, high pressure day. That is why cars run better in nice weather. This is also why there are weather stations and correction factors built into dyno's. These correction factors are what HELP stabalize the dyno results from day to day.
There are tons of reasons why boost will vary from car to car, here are just a couple,
1st, sensor or gauge calibration.
2nd, Atmospheric pressure.
i altitude
ii barometric pressure (weather)
3rd, Engine airflow
I say this because I have seen threads where members will literally butt heads over 1-2psi and 5-7 rwhp.
With all the above in mind lets say The manufacturer advertises 7 psi, and customer "A" nets only 6.25psi, was he wronged? Would it find its way to a forum and state that he was robbed of .75 psi, possibly. If it is under estimated, then the results are only a bonus. Kinda like finding a $10 bill in the dryer that you had no idea you lost.
With all the above variables in mind, you have to understand that this stuff needs to be averaged and underestimated.
