one eyed willy
Pizzle fo shizzle
block back from the machine shop:$460
stock bore,all measurements checked.honed.
crank,flywheel,rods/pistons and UDP all balanced
flywheel turned
rings file fitted
table full of parts:
manley rods with arp 2000 bolts
JE -17CC pistons
all ARP fasteners
Stock crank
GT500 oil pump
canton/MMR windage tray
assembly lube
this book sucks for what it says it is,it didnt help me much at all,dont waste your money.
main studs in and bearings lubed up,arp main studs torqued to 22 on the outer bolts and 60 on the bigger inner bolts,side bolts torqued to 30 (all ft-lbs)
crank in, untorqued and re-torqued 3 times to get the lube worked in real good.
JE psitons w/ 4 lock rings per piston,this took some time.
All pistons in,all rings offset properly, and ring gap at .022.piston to wall clearance is .004.
GT500 oil pump installed
rear main seal installed and oil slinger.i used the old gasket as my tool to force the new gasket in by tapping it in with a hammer. i just put the old gasket ontop of the new gasket and tapped on the old gasket.the oil slinger slide right in,just had to force it in with the flatside of a hex head wrench.
