one.wicked.stang
Grudge Race?
I have a 2006 Mustang GT (Automatic) that I had the FRPP Hotrod Cam installed on. When the car is at a low idle sitting still (parked) it runs fine, it also runs fine at freeway speeds. However, in stop and go traffic conditions or low rpm cruising in town light to light driving the O/D off light will start flashing and the car starts driving badly (wont shift, higher revs between shifts, stuff like that). If I pull over and shut the car down then restart it and get out of the conditions mentioned it runs great. Anyone else have a similar problem or heard of this. With the stock cams in I NEVER had this problem. The tunes are from Bamachips, the tune the day of the install was not modified for the cams and it had this problem, the tune for the cams has this problem also. Could it still be a tune issue or something else?
