Gray Ghost GT
Road Racing Fanatic!
I'm new to this forum having purchased my first Mustang - a 2009 GT, but have been participating in HPDE events for the past 5 years in a dedicated track car - C5 Corvette - in HPDE 3/4 (Advanced Solo).
I prepared the following "HPDE Basics" information for my local club and thought I would share with the membership here. I hope you all find it helpful. I know we have many experienced members on the forum that may want to chime in. Perhaps this topic would make a good "sticky". Mike
High Performance Drivers Education (HPDE) Wikipedia
Lets take a few laps: HPDE lap around VIR Grand East Circuit and HPDE lap around Watkins Glen
You will need to purchase a current SA20xx certified racing helmet (NO motorcycle helmets) along with wearing jeans, sneakers and a long sleeve shirt. Each club has their own set of rules – these are pretty common. There are many helmet manufacturers/models. Some models fit different head shapes better than others, e.g., Shoei, Bell, G-Force, etc.
Initial recommendations to prepare your Mustang for HPDE include: (1) Safety, (2) Braking and Cooling, (3) Suspension – you usually don’t need more horsepower or need to spend large amounts of money as you get into this HPDE hobby. Seat time.. Seat time.. Seat time..
1. SAFETY: Ideally, you will eventually want to invest in a set of race seats, roll bar and set of 6-point harnesses. However, if you are just starting out in HPDE 1 (and applies to HPDE 2) OEM seat and belts are good enough. If you want to upgrade for a reasonable price - a harness bar with a set of 4-point Schroth Profi II ASM FE harness are a great option because they can be converted to a 5 or 6 point harness when you’re ready to purchase race seats.
2. BRAKING and COOLING: Bleed the brake system with fresh DOT 4 Super Blue (or Gold) ATE Fluid (or similar quality fluid) and use fresh synthetic motor oil. Front brake cooling ducts are highly recommended given the weight of the Mustang, and a set of stainless steel brake lines - these really work!. If you're in HPDE 1 you can often stick with your OEM brake pads, but I recommend upgrading to either Hawk DTC-60s, Carbotech XP10s or similar because most beginners tend to use their brakes too much.
3. SUSPENSION: HPDE 1 and 2, really no need to touch your suspension till you get into HPDE 3+. It's preferred to learn valuable car control skills preferably on a good set of street tires. A wheel alignment and corner balancing makes a significant difference.
Here's a good TOP 25 "Basics" for HPDE/road racing - Enjoy!
1. Slow in / fast out. If you start turning and the car keeps going straight (push/understeer) you are likely entering the turn too fast. In my experience this slows down lap times more than anything.
2. Look ahead. The proper line is key for fast times. Looking ahead allows you to keep the car on the proper line. This may mean looking at the next turn before you are out of the current turn. Often requires looking out the side windows rather than just through the windshield.
3. Use the whole track. This goes with the proper line. In general, you want to make the turn as gradual as possible to allow for greater speed. However, stick to the clean line. Gravel and marbles will often accumulate the most off line and you will lose traction if you stray into it.
4. Whenever possible, ride with an experienced driver before your runs. Even better, co-drive your car with a good driver. This allows for great feedback on what your car can do for a particular course, and where you can pick up more time.
5. Try to get your hard braking done in a straight line and take a line that allows you to get the car straighter and on the gas earlier in the turn, particularly before a straight.
6. Unwind the wheel as you accelerate out of the turn. Getting on the throttle as you come out of the turn will generally cause the back end to step out (over-steer). Unwinding the wheel allows you to control the over-steer and generate more speed. Again, use the whole track.
7. Basic mechanicals. Full fuel, fresh brake fluid, at least 50% left on your brake pads, secure battery tie down, etc. Make sure the engine oil is topped off (continuous running track courses, add 1/2 Qt. over full).
8. Tire pressures. Most newbie’s start out with high pressures, mainly to save the sidewalls of the tires. Start by adding 6 psi to each tire, COLD. Cold, like before you leave home in the morning cold. After each run (each run because you'll be picking up speed on each run) check to see that you're not running onto the sidewalls. Wear on the corner of the tread is OK, but not past that.
9. Interior. Get everything out of the interior that can move. Floor mats, radar detectors, CDs, etc. You'll be braking and turning harder than you ever have before, and you won't believe the stuff that'll come out from under the seats.
10. Personal. WATER, WATER, WATER! And eat light. Especially if you get some runs with an instructor, it's easy to get a queasy stomach.
11. Leave your EGO at the door, I can’t stress that enough. I see way too many guys wrecking their cars just because they THOUGHT they are great drivers.
12. DO NOT FOLLOW THE GUY IN FRONT OF YOU BLINDLY!!! You will be surprised how many guys DO NOT take the correct line. A bad line will get you one of two, a bad lap time or an off track experience.
13. BE SMOOTH!!!! Do not force the car or yourself, be smooth, speed will come with that.
14. If you come into a corner too hot you can ride it out and go off track a bit. Here's the kicker, if you accidentally get two wheels off track RIDE IT OUT! Don’t panic and try to yank the car back onto the pavement. The car will spin and when you regain traction you'll probably be pointed at a wall!
15. Someone who is in your mirrors did NOT start there, so they are faster than you are, let them by. Do not get frustrated by people that won't let you by. Pull into the pit, tell the course marshal you want some space, and they will let you back out into clean air.
16. Pay attention at the driver's meetings. Make sure you know and FULLY understand the passing zones, and passing method used by the people running the event. You may know what the flags mean, but make sure they are using them the way you think they should be using them.
17. Do NOT use the brakes on the cool down lap. Use it to cool down the car, but also drive the "perfect" race line in super slow motion. If you can't put the car where you want it at 40mph, how are you going to do it at 90mph? When you return to the pits, do NOT apply the handbrake. Chock the wheels and after about 45-60 seconds roll the car forward 6"-8". This will allow the part of the rotor that is inside the caliper to breath too. Pop the hood. While the hood is up, look for fluid leaks and double check your brake fluid level.
18. Know where the flag stands are, check them every time you go by them.
19. When there are unsafe conditions on the track, GET OFF THE TRACK. Pull into the pit, don't be afraid to end your day early. It's far better than having it ended early for you.
20. It makes sense to change to open lug nuts. The closed ended ones can get junk in the end preventing proper torque specs. This is referred to as "acorning." It would be a bad day losing a wheel at any kind of speed.
21. Screeching tires on a corner are fine, but "howling" tires are bad. After a few corners, you'll know what I mean. When the tire noise deepens and starts to "howl," you are right on the edge with street tires, so be very careful.
22. DO NOT LIFT if you're in a corner. The load of the car transfers forward with the deceleration, the rear tires get light, and the back end can snap around on you. If the rear then grabs, you'll be heading directly into the inside of the corner, possibly at a wall or other fixed obstacle.
23. Carry two extra bottles of brake fluid, a bleeder bottle, set of spare pads and rotors, and an extra quart or two of oil. DO NOT pay attention to the gas gauge, it may not read properly since the S197 has a saddle-bag shaped gas tank. The cornering can slosh fuel back and forth enough to create false readings on the gauge.
24. Your OEM rotors should be good for 3-5 events, again depending on the heat. Replacement rotors (they will wear and crack eventually) are cheap at Advanced Auto or Rock Auto or someplace like that. I carry a spare set with me so I can change out bad ones and keep on driving the rest of the weekend. Avoid drilled rotors - not good for HPDE because they will crack fast and ruin a good weekend.
25. Don't use your transmission/engine to slow your car as you enter a turn. USE your brakes! Brake pads are much less expensive to replace than repairing your transmission. It may sound "cool" to hear your car whine down as you enter a turn, but you're placing a lot of stress on your transmission and its "uncontrolled deceleration" that can spin your tail end around. Brake steady/hard and shift.
HPDE 3 drivers should learn and become proficient in Heel-Toe Shifting to rev match your RPMs while down shifting. Check out these videos: video #1 and video #2 to learn the "Heel - Toe Technique". You can purchase a custom gas pedal extension plate to make this easier.
Here's some good reading for HPDE:
Secrets of Solo Racing - Henry Watts
Speed Secrets - Ross Bentley
Driving in Competition - Alan Johnson
Drive to Win - Carol Smith; and A Twist of the Wrist – Lawson & Rainey
You can also learn the layout of various road courses by watching HPDE videos on YouTube, but don't rely on their "line" since they may be wrong or specific to their cars setup.
