one eyed willy
Pizzle fo shizzle
so im installing my new e-boost street boost controller. it needs a rpm signal, im also installing a raptor shift light that needs a rpm signal. so i grabbed the #8 coil white/red i think (not the solid red), and the raptor seems to be working fine but the boost controller does not show the correct RPM. i set it to 8 cylinders but its still fugged up.in the instructions it says it can do a "square wave" signal, what the hell is that? is there a different wire i should be hooking this thing up to?i can see numbers bouncing around they just dont make any since to me.
