tmcolegr
It's All About the Build
My 4.6L 3V billet oil pump gears should be arriving tomorrow. Can anyone give me the recommended torque spec on the tapered screws which retain the cover?
Thanks
Thanks
Should be 80-100 inch pounds.
Depends on who you ask. I use 100 inch pounds with blue Loctite. Other people say to back off the torque if you use Loctite. I've always done the pumps at 100 inch pounds and it works.
So stock gears shatter above 600-700 RWHP...?
So a 550 crank HP 3V is OK with stock gears?
Whats involved in the install? Can this be done without tearing up the engine?
Supposedly melling came out with there 3v pump also now , while I don't know the specifics on this one yet the termi guys swear by it .
They have had one for awhile .(like in 06) It is ok if the VCT is turned off from what I understand . If you want a "3v" billet pump then the Triangle gears are it , but then I have been wrong before . LOL!Supposedly melling came out with there 3v pump also now , while I don't know the specifics on this one yet the termi guys swear by it .
