I have aproximately a 6 Gallon Tank in the trunk for intercooler coolant and eit hthe lines and Heat Exchanger it probably holds about 7.5 gallons if i had to estimate it
The Pump is a Meziere Remote Intercooler Pump, which has a 20 GPM flow rate
Theway the lines are set up is the fluid leaves the tank and enters the Intercooler, exits the intercooler into the Heat exchanger, then back to the tank. This was done to make sure that when i add ice to the tank, tthe coldest fluid reaches the Intercooler first for best performance. I realize thiswill increase temps for normal street driving but does not explain the near 80-90 degree shifts in temperature that i describe below.
I have been doing some testing lately and on pretty cool nights, High 50's to low 60s, my IAT temps are ranging from 118 to 198. This is all at a 75mph cruise speed on Cruise Control at about 2500rpm. In a period of 5 minutes the temps will slowly increase and get as high as 198 degrees. Then in a period of about 30 seconds, the IAT temps will come all the way down to 130 or so, and continue to fall for another minute or so. Then the process repeats itself
I have checked the pump to make sure it is pumpig fluid and it is. The fluid is definately getting hot, much warmer than 100 degrees but i do not have an exact temp. I do know the fluid in my Stock KB tank never reached over 100 degrees before. I have pulled over many times during the rise in temps to check that the pump is still pumping and it is each time. The only thing I can think of is that the pump might be stopping and starting somehow during the course of driving but everytime i check it it is pumping
TRhe last time i was at the track it wasnot pumping fluid and i had to bleed the pump to restart it but sicne then it has been running well. Any ideas, thoughts, or suggestions?
