Hello everyone. I need your advice on how to proceed. Just had the Aeroforce Interceptor installed and am quite surprised and confused as to why the numbers I'm seeing for the IAT2 and Coolant temps. They are identical. I'm using the VMP Triple Pass Heat Exchanger and the Bosch Intercooler Pump that came with the TVS kit.
The temps rise to 190 or so then stabilize. IAT is roughly 115-120.
With the key on but the engine off I can hear the pump running. With the engine running, I look into the tank ad see why I would call mild gurgling. The shop that tuned the car said I should be seeing "violent" bubbling.
The fact that the numbers are the same tell me the pump isn't working but I can hear it!
Please help point me in the right direction because I don't believe what I'm seeing is very good for the car.
