Driveshaft balancing the Ford way?
GlassTop09
Farmington, NM
Ok, the verdict is..........fact check-TRUE!
This S197 center carrier bearing assembly setup does exactly everything the folks at JXBPerformance said it would do to the letter........
The Track version durometer bushings are very stout when fully compressed into assembly........I could only move the center bearing 1\8" of movement.......most of this movement was found at the 2 mounts to unibody......not in the center bearing sandwich bushings inside the JXBPerformance carrier assembly. So, when JXBPerformance said this setup removes the driveshaft slop in the center carrier area of the OEM Ford 2-piece DS.......they ain't lying.
Driveshaft is quiet as a church mouse during rotation (tested up to 70 MPH to date.......so far, so good) w\o any harsh NVH anywhere........but since I have a fully trans mounted MGW shifter (installed on a Blowfish Racing Remote Shifter Mount bracket.......the V2 version.....is now discontinued) I can feel the extra NVH from this firmer mounting thru the shifter handle (mostly thru the front U-joint at the trans flange) but the connectivity improvement thru to the rear axle is very noticeable thru my Eaton Detroit Tru-Trac diff when the clutch is engaging\disengaging........in a lot of ways it seems to have the connectiveness feel of a 1-piece driveshaft (I also own a Ford Performance 1-piece DS w\ the 2 Spicer 1350 U-joints & ran it in this car from 2018 thru 2022 on a full BMR 05-09 S197 rear suspension setup before I put my OEM Ford 2-piece DS back in so I know of what I'm talking about) but is much smoother due to the 2 CV joints in the rear 2-piece DS half shaft section along w\ the Roush 3rd Link UCA assembly (a Roush-modified OEM Ford 07-09 GT\GT500 UCA assembly.......is now discontinued) & OEM Ford 07-14 GT500 rear LCA's I have installed replacing all the BMR suspension parts as well but retaining all the full rear axle control under full WOT launches........at the OEM Ford 08-09 Bullitt ride height (have a full set of OEM 08-09 Ford Bullitt take-off springs installed).
IMHO, I give this JXBPerformance S197 DS Center Carrier Assembly a thumbs up as I find all the descriptions given by JXBPerformance are indeed true as I also felt\observed as well.
I believe y'all will like the Street durometer version bushings just as well.......they're just a bit softer than the Track version but not by a lot......FYI.
As usual, YMMV............
The install was pretty straight forward..........I did the install w\ my Kooks mid pipe still mounted (detached the exhaust pipes from the mid pipe & bungiee'd the pipes out of the way......video showed to remove the mid pipe section) & the DS still mounted in the car on jackstands..........but if you have a set of the HF Daytona 6-Ton jackstands w\ a 20" stand height set under a pair of Steeda Jacking Rails it ain't half bad........but a lift is THE way to go if you have access to 1. I found that if you have a 4" hand held grinder using either a 4" grinding wheel or cutoff wheel, I could access the top area section just behind the old carrier mounting flanges thru the area between the mid pipe ends & cut the upper flange section out to remove the metal housing part then a good & sharp 2" pocket knife made short work of the rubber section right down to the part of the rubber that will be reused (found 4 sections already had cracked & separated). The rest is as shown in the install video. I used some blue Loctite on all the bolts for insurance. Install w\ the lettering facing towards the front of car (or towards the transmission) so all properly centers up inside the carrier assembly when mounted.........as instructed in the video.
Good luck!
PS edit--install video won't run here so go on JXBPerformance web site & run it.
Gladams
Oak Grove, Missouri
Good luck!
Outstanding write up. I can’t wait to get mine installed. I have the Barton Hybrid 3 trans mounted and the boomba race transmission mount, so NVH through the shifter hopefully won’t be too bad. Thanks for doing the write up. If I can’t get a lift, my son said he would do the crawling around on the floor for me. He’s 26 and about the size of a toothpick. Thanks.
GriffX
If you remove the old bracket, alternatively to cut it through, there are 4 tiny tack welds at the top, which can be grind off very easy.
After my DIY rubber mod the movement of the shaft is less than 1/8". Will see next week.....
GlassTop09
Farmington, NM
You're correct.....................if you also remove the midpipe. I tried to cut these tack welds initially........the 2 facing towards the rear I could get to, but the 2 facing over the midpipe, there just wasn't enough room to safely maneuver a 4" handheld grinder w\ disc & reach these 2 tack welds.......but I could easily do what I described w\ the midpipe still mounted thus the direction I took.
I understand the option of cutting the tack welds to preserve the parts...........but that wasn't in the cards for me as I fully understood that this setup is a 1-way affair.........once done you're committed to it going forward.......I didn't have a problem w\ that since this part exudes of being a well thought out & engineered design thus any perceived outstanding issues were already resolved by the folks at JXBPerformance.
So, I just installed it essentially according to the instructions given...................the rest is history. The part performs exactly as described that it would.
My take on this..............................
JC SSP
FL
What’s made you go from 1-piece shaft back to factory one?
GriffX
So, finally, first impression. The drone at 67 is gone, no noise so far, but must test it with higher speed also.
I got some NHV in my seat with medium load acceleration from low rpm, it's like some growl so not annoying (not yet).
I guess I can improve it further by changing the aluminum spacer with rubber disks like JXB does?
Overall the drivetrain feels very solid. I call it an improvement. :)
Gladams
Oak Grove, Missouri
Got mine installed today using Jack stands. I agree that the JXB works as stated. I’m so glad I bought this and so far saved money on a one piece DS. Thanks JXB and thanks to everyone for your write up’s.
GriffX
BTW, am I crazy, or does the tires brake loose much sooner now?
GriffX
You are not crazy. Have to watch take offs, but I like how solid it feels. No more slow speed clunky sounds.
Exactly, so far very worth the work.
An other mod I wished I did much earlier, together with the noise insulation and the aerodynamic stuff.
GlassTop09
Farmington, NM
Now y'all can understand why I said that after this mod the 2-piece DS now has the connectiveness of a 1-piece DS........by tightening up the lateral side to side & vertical up\down flexing inside of the front CV joint from the center carrier moving about & maintaining the axial (or rotational if preferred) driveline centerline throughout, this stops soaking up the transmission of engine TQ output thru the driveline thus "feels" more connected (or solid if preferred) to the rear axle while also reducing the "load" thru the front CV joint at the same time.........the main joint that commonly fails when this 2-piece DS is put under high initial TQ loads............
This also vastly improves the rolling moment of these 2-piece DS's making acceleration quicker as well due to the 2-piece DS being much easier\free to roll (or turn if preferred) .........which is also part of what y'all are experiencing.............as long as the rear axle suspension\tires can get it put to the ground w\o wheel spin.........
For those so inclined to know\understand the physics behind all this................
2 different methods of achieving the same goal.....................
