I am using Saleen gauge as well. It is only 60-70 degrees here in Colorado right now, and I do have a larger than stock intercooler tank which gives me a little more capacity. I'll be curious to see the AI temps once the heat really hits here.
The stock location interferes with my brake duct cooling. I have the Shebly Brake duct/fog light kit and with the h/e in the stock location I can't use the brake ducts. If I move it up to the 2010 location that would let me use the ducts for open track days etc. Plus I had to insulate the hose coming out of the h/e as it sat against the fog light and developed a small hole which if not discovered could have been bad. So moving it helps me alleviate a couple of small issues.Whats wrong with the stock location?
Looks good.....cut and weld?? Also where did you get your AFCO H/E at??
Looks like the JPC coolant tank is available
http://store.jpcracing.com/Fabricated-Aluminum-Saleen-Intercooler-Tank_p_1351.html
Its been available all year.....just not any bigger from what I can tell.
Pix of one installed are here.
I took my Canton tank that was made for a GT500 and had it cut down in height by 1 1/4 inches to clear my hood and the Saleen Extreme CAI. Even with it being cut down it still is almost twice as much capacity as the stocker. In addition I added the AFCO H/E which gives me even more capacity.
Why did you need the tank cut to clear the hood? I had a canton GT500 tank there for 2+ years unmodified and it cleared the stock hood with no problem.
did you not read the post RIGHT above yours? lol . its not available yet.
