cruisin
I couldn't find anything on this. I did try to search though.
So I've removed my blower, (had a Saleen, 2.95" and 10% OD) it was pretty much maxed.
So now I've stepped up to some turbos. Nothing crazy but from what I can see, the mid to upper range would suit a turbo or turbos.
I haven't put it on the rollers yet but has anyone tried the 127500 with turbo(s)
Obviously to make the most possible, I would have to swap the cams out.
The engine will spin to about 7500. I don't think there is a need to push for any more.
Locks are done, as are the springs with beehives.
I should have it on the rollers before the end of the weekend.
I should add, that I'll be running somewhere around 8-10 psi for the street and 25-30 for track. Likely on the lower end, if the numbers are ok, if needed, I can always run the on higher end for a few passes.
T3/T4 61mm journal bearings.
